Engine lid, Large gap why |
DavidSweden |
Aug 4 2016, 03:44 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Looking for some advice, the engine lid on the passenger side has a large gap but it looks ok on the drivers side any ideas why?
Thanks (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1470347066.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1470347067.2.jpg) |
Chris914n6 |
Aug 4 2016, 03:57 PM
Jackstands are my life. Group: Members Posts: 3,336 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Shrinkage from the cold (IMG:style_emoticons/default/poke.gif)
Actually it's just out of alignment. Should be consistent with all the other gaps on the car. |
toolguy |
Aug 4 2016, 04:01 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Also look like it's a little low on the right side by the window glass. . better
check the hinge bracket on the firewall for cracks. .this is what happens when the hinge angle bracket cracks at the curvature. . also adjustable side to side by loosening the hinge bolts and slide it to the right. . You're missing the rear window to engine deck lid seal also. . |
EdwardBlume |
Aug 4 2016, 04:28 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
As noted its off on both sides.
Looks like you need a window seal... |
worn |
Aug 4 2016, 06:26 PM
can't remember Group: Members Posts: 3,163 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
76-914 |
Aug 4 2016, 10:12 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC there is some black edge trim for the lid.
bretth |
Aug 4 2016, 10:42 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Your sticker reminded me that I actually heard a Ziebart commercial on the radio today. I thought they were a company gone many years past.
Brett |
DavidSweden |
Aug 5 2016, 10:29 AM
I had a look at it today and i dont see how the lid can be adjusted from side to side.
Whats the procedure? Thanks |
matthepcat |
Aug 5 2016, 11:14 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I had the same thing on a previous 914. I had to weld in new mounts from restoration design. One side was cracked and failing.
Lo-Fi Version | Time is now: 8th June 2024 - 12:20 AM |
