Need help identifying plated parts, Last of the unidentified 73 914 2.0/4 plated parts |
Jett |
Aug 7 2016, 11:37 AM
Senior Member Group: Members Posts: 1,641 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I need some expert help identifying a few remaining parts that came back from the various trips to the plater. We also may have included doubles (IMG:style_emoticons/default/smile.gif)
Attached thumbnail(s) |
Dave_Darling |
Aug 7 2016, 12:25 PM
Not sure about most of them--they could be any of a bunch of washers/nuts/bolts.
D: Wedge pin for ball joint (ALWAYS REPLACE, as it says in the manual) O: I think clips for brake hoses? E: Clamps for holding the heater blower onto the pedestal it sits on (73+, only 1 used) X: Brake caliper lock plates --DD |
Garland |
Aug 7 2016, 12:40 PM
Restoration Fanatic Group: Members Posts: 1,330 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
A. Headlamp linkage pivot, on lamp housing.
C. Spacer's for bumper dog bones. V. Linkage clip door handle rod. W. Under dash foot air vent mounts. Z. Hand brake pin to caliper. O. Hand brake cable mounting clip to trailing arm. Early cars. Y. Could be door stop hinge pin. E. Could be heat blower motor mounting clamp in located engine bay. |
Chris914n6 |
Aug 7 2016, 02:14 PM
Jackstands are my life. Group: Members Posts: 3,338 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
T- one of 2 used to mount the blower box to the cowl, R- looks about right as a match.
W- 2 each side. Fresh air splitter boxes to floor ducts. F & G- Nylocks not standard issue, post 914 invention. K- looks like American door panel fasteners. U & N headlight related? |
echocanyons |
Aug 7 2016, 03:29 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
X are brake caliper retaining plates.
JeffBowlsby |
Aug 7 2016, 04:36 PM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I love these games. Some of the parts should be rephotographed...too small or the wrong orientation to ID them.
I know what P is, but I will let someone else speak up first. |
Dave_Darling |
Aug 8 2016, 12:18 AM
(IMG:style_emoticons/default/agree.gif) I can't even see what T and U are. I know I've seen the one labeled P before, but I don't remember where it was.
--DD |
cwpeden |
Aug 8 2016, 12:51 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
K: mounts for fog lamps, one on either side for pivot
ClayPerrine |
Aug 8 2016, 12:57 PM
Life's been good to me so far..... Group: Admin Posts: 15,523 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
R - Engine Tin screw
O - Park Brake Cable clips. Holds the park brake cable to the rear trailing arm. V - Door handle rod retainer. Holds rod to door handle or latch mechanism inside the door. W - Fresh air control box hold down bolts. X - Brake caliper nut backing plates. Z - Park brake cable pin. K - Fog lamp mount cup. E - Blower fan strap. B - 8mmx1.25 stud used in various places on the engine. D - Ball joint wedge bolt. Do not reuse. Get new ones. T - Half of the 6mm clip nut for the door pad. |
JoeD |
Aug 8 2016, 01:24 PM
Member Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States |
I love these games. Some of the parts should be rephotographed...too small or the wrong orientation to ID them. I know what P is, but I will let someone else speak up first. Taking a stab- "P" looks like one of the speednuts securing the engine deck lid and PORSCHE letters on my car- at least, what was on my car when I bought. Don't think they were stock... |
JeffBowlsby |
Aug 8 2016, 01:26 PM
Nope...
JoeD |
Aug 8 2016, 01:28 PM
Jett |
Aug 10 2016, 12:08 AM
(IMG:style_emoticons/default/smile.gif) lol you folks are the best. I'll take pictures of the unidentified items in the am (IMG:style_emoticons/default/smile.gif)
Thanks for all the help!!! |
Lo-Fi Version | Time is now: 10th June 2024 - 05:06 PM |
