| MikaM |
Aug 11 2016, 10:42 AM
Newbie ![]() Group: Members Posts: 8 Joined: 2-November 14 From: Finland Member No.: 18,080 Region Association: Europe |
I need information how to weld gearbox 914/-70, mixture or welding instructions (IMG:style_emoticons/default/smile.gif) Mine has some cranks near the starter motor..
Thank you (IMG:style_emoticons/default/smile.gif) -Mika |
| bretth |
Aug 11 2016, 12:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Welding Aluminum is not easy. I have seen pros screw it up. Maybe someone else will have better info but you may need to take it to a pro if you have never welded AL before.
Brett |
| Dave_Darling |
Aug 11 2016, 12:17 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Isn't the transmission case a magnesium-aluminum alloy? If so, it's even harder to weld.
--DD |
| Beebo Kanelle |
Aug 11 2016, 12:50 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
| Mark Henry |
Aug 11 2016, 01:10 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Mag is hard to weld and it warps, you can do it with just gas welding, but you need the correct welding rod. Stuff has to be super clean.
You can only weld about a 1/4" at a time in a couple different places on the case, let it fully cool, repeat, until you're done. Bug drag guys often weld bars (gussets) to the bottom of the case, to keep them from breaking, it can take a couple of weeks to weld them in fully. |
| MikaM |
Aug 12 2016, 04:18 AM
Thanks (IMG:style_emoticons/default/smile.gif) I'll try to get it welded in some specialist..
| bretth |
Aug 12 2016, 08:27 AM
| Krieger |
Aug 12 2016, 09:02 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,840 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
What would it cost you to replace the entire tranny vs welding?
| mlindner |
Aug 12 2016, 10:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,739 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Mike...are you sure they are cracks, a lot of casting marks look like cracks but are not. Best, Mark
| mb911 |
Aug 12 2016, 11:22 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,723 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
They are magnesium. I weld 911 fans and housings weekly for customer's. I have very expensive mag rod $900 for 4 lbs.. Oxy is a new one to me as mag is flamable. TIG uses inert gas so it can't start on fire with oxygen.
| MikaM |
Aug 12 2016, 11:29 AM
I'm quite sure (IMG:style_emoticons/default/welder.gif)
https://pix.sfly.com/_0_1rY https://pix.sfly.com/RZ_qjU -MikaM |
| stugray |
Aug 12 2016, 11:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
| MikaM |
Aug 12 2016, 11:37 AM
What would it cost you to replace the entire tranny vs welding? Here in Finland a lot, you probably have to ship it somewhere else (IMG:style_emoticons/default/wink.gif) I have few connection's to schools where they teach welding.. I,m counting on these friends (IMG:style_emoticons/default/smile.gif) |
| Mark Henry |
Aug 12 2016, 12:14 PM
| MikaM |
Aug 12 2016, 12:40 PM
| 76-914 |
Aug 12 2016, 01:02 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,865 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I have a case that you can have for the price of shipping. Pm me if you want it. Kent
| MikaM |
Aug 13 2016, 08:23 AM
PM send (IMG:style_emoticons/default/smile.gif)
| stugray |
Aug 13 2016, 12:49 PM
| oldie914 |
Aug 14 2016, 02:13 AM
Member ![]() ![]() Group: Members Posts: 119 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None |
I also have a case you can have. Shipping from Germany to Finnland would cost about Euro 30. If you are interested, I will send pictures.
Keep in mind you will need to readjust the R&P if you change the case. Need to set pinion depth, differential bearing preload and backlash. |
| MikaM |
Aug 14 2016, 03:14 AM
I also have a case you can have. Shipping from Germany to Finnland would cost about Euro 30. If you are interested, I will send pictures. Keep in mind you will need to readjust the R&P if you change the case. Need to set pinion depth, differential bearing preload and backlash. What R&P mean? I sent you PM (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 3rd March 2026 - 05:58 AM |
