N_Jay |
Member ![]() ![]() Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None ![]() |
Wondering what people think about getting rid of the side markers when re(sort-of)storing a 914?
Yes, to make it cleaner? Yes, to get rid of holes for water and rust reasons? No, because it is not original to the car? No, because it is less safe? Any other ideas? Better looking side markers? Flat ones like a 924? Small ones like a 90's VW/Audi? Thoughts??? |
sb914 |
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,526 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California ![]() ![]() |
AZ914 |
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,469 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region ![]() |
Agree with SB914. I shaved mine when last working on the fenders. I like the clean look.
However, if you have an all original US-SPEC car (they were not on the Euro models), and are restoring for investment purposes, I guess I'd leave them. |
iwanta914-6 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None ![]() ![]() |
I prefer without, to hell with US-Spec originality!
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
They really look bad on M471 fender flares!!!
jor |
Just happy to be here. ![]() ![]() Group: Members Posts: 183 Joined: 28-July 14 From: LA Member No.: 17,693 Region Association: Southern California ![]() |
I like them in a cheeky, 70s-styling way. Big round dots. Cindy Crawford's beauty mark.
luskesq |
Member ![]() ![]() Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California ![]() |
They are there for safety/visibility reasons. I wired mine so they blink when turn signal is activated. I had a euro version where the side markers were much lower and more to the front that was quite acceptable.
Keith |
era vulgaris |
J is for Genius ![]() ![]() ![]() Group: Members Posts: 983 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States ![]() |
I love them and would only remove them from a car with fender flares. On a narrow bodied car, I think it looks naked without them.
Also, probably people who lived through the 70's like them less than those of us who didn't. I think all that tacky 70's style is really cool! |
gcrotvik |
Member ![]() ![]() Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest ![]() |
I don't really care for them. I'm leaving them on my 74 concours restore (for obvious reasons).
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Every time this topic comes up, the results are the same. The majority prefer the clean look without the warts (myself included). Some like them for originality (although it was a US only thing). Some replace the warts with more modern lower-profile markers (and often move them back behind the wheel) as seen below.
Bottom line is, it's purely a matter of personal preference. You should do what you like best on your car. (IMG:http://www.914world.com/bbs2/uploads/post-226-1306205415.jpg) |
Toast |
Not bad for carrying sway bars. ![]() ![]() ![]() ![]() Group: Members Posts: 3,380 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region ![]() |
Without definitely. They look like zits that I really want to go away.
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,815 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Shave it! (IMG:style_emoticons/default/welder.gif)
veekry9 |
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada ![]() |
Wartlamps,skintags.
A few other European autos were quick to solve the new mandates in the '70s the same way. They didn't want to,but were forced on short notice to comply with new visibility legislation. They used off the shelf aircraft or marine lenses,to expedite,without incurring production costs. Easily replaced with a modern,flush-fitting leds. The Cayman has a nice design that might suit placing near the front lense. ![]() Looks nice,low profile. ![]() Something like this might appeal,the lenses and bases in molded acrylic/polyurethane as a pair in the mold. Smooth,flush,mod,waterproof,bulbless,unobtrusive. (IMG:style_emoticons/default/smile.gif) / This is the resin for such custom,or 'factory emulating' marker and turn signal lamps. http://www.hapcoweb.com/ultraclear.htm A mold with optical surface smoothness is the next step,once a design has been decided. A <6-8 RA polish and plating of a P20 block http://www.hudsontoolsteel.com/technical-data/steelP0 with heaters and coolant lines installed,a vacuum pump,then production can begin. (IMG:style_emoticons/default/smile.gif) ![]() Flush,or maybe a 2mm proud roundel led to 'mimic' the aftermarket lamps installed at the factory. And yes,the rules are that they must be as high as the wheel height. (IMG:style_emoticons/default/huh.gif) / |
struckn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region ![]() |
Mine are gone but the wiring and connectors remain out of sight tucked behind the fenders should the need occur to put them back on.
I also have some cheap reflectors that I glued earth magnets on the back so if for any reson I need reflectors at night I can slip them on the fenders. |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
They look like a big orange pimple. Squeeze them off.
Craig at CAMP |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
They weren't the best design Porsche ever came up with. If I were repainting a car, I'd leave them off.
On a stock car, they are fine. If you use anything else, it will look like shit and be wrong. I like the idea of some sort of side markers behind the wheel wells (between the doors and wheels) if they are appropriately Euro looking and tasteful. My $.02. |
N_Jay |
They are there for safety/visibility reasons. I wired mine so they blink when turn signal is activated. I had a euro version where the side markers were much lower and more to the front that was quite acceptable. Keith How much difference was there? I thought euro did not have any. |
N_Jay |
Well, I am not overly into "originality. I have neither the money nor the patience to try to restore for "value".
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Don't like them
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,588 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Don't like them either, got rid of them when I had the car painted.
Lo-Fi Version | Time is now: 31st July 2025 - 05:09 PM |
