| pbanders |
Oct 13 2016, 09:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 990 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
What's involved with installing retractable seat belts? When I bought my 1970, it had no belts at all. I put in some crappy stock non-retractable belts years ago, but they are and always were crappy. I'd like to put in something better. Suggestions? Just lap and shoulder retractable should be all I need.
| SirAndy |
Oct 13 2016, 09:39 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Don't!
I have actually come to really like the non-retractable belts in my '70. Set them once and forget about it. (IMG:style_emoticons/default/piratenanner.gif) |
| 914werke |
Oct 13 2016, 09:42 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,606 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Tougher on the early cars as the back wall has no recess for them, but you probably new that.
| jeffdon |
Oct 13 2016, 10:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Don't! I have actually come to really like the non-retractable belts in my '70. Set them once and forget about it. (IMG:style_emoticons/default/piratenanner.gif) Andy - My 72 has belts that sorta retract. They are a bit balky. Can I make them non retractable? Or are you talking track belts? |
| pbanders |
Oct 13 2016, 10:25 PM
Tougher on the early cars as the back wall has no recess for them, but you probably new that. I've got the later back pad with the cutouts in it, I assume that helps. I'd need to remove the back pad, but it's attachment to the firewall that has me wondering. |
| SirAndy |
Oct 13 2016, 11:23 PM
My 72 has belts that sorta retract. They are a bit balky. Can I make them non retractable? Or are you talking track belts? Not talking track anything, the early stock belts don't retract. They are adjustable but stay tight once set. I very much prefer them over the retractable ... (IMG:style_emoticons/default/smile.gif) |
| cary |
Oct 14 2016, 08:25 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
This is what I'm running in my 73 DD.
Which uses the later mounting points. But they should be able to come up with something for you. https://www.seatbeltplanet.com/seatbelts-an...ts/332/view/125 |
| mepstein |
Oct 14 2016, 10:47 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Don't! I have actually come to really like the non-retractable belts in my '70. Set them once and forget about it. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/agree.gif) one of those special early car things. |
| mramber |
Oct 14 2016, 11:31 AM
Member ![]() ![]() Group: Members Posts: 87 Joined: 14-April 13 From: Minneapolis, MN Member No.: 15,768 Region Association: Upper MidWest |
Don't! I have actually come to really like the non-retractable belts in my '70. Set them once and forget about it. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/agree.gif) one of those special early car things. Cool, I thought I was the only one, but mine work the same way! Maybe it was installed like that at the factory along with the rust??? (IMG:style_emoticons/default/lol-2.gif) |
| RenoRoger |
Oct 14 2016, 11:34 AM
Member ![]() ![]() Group: Members Posts: 96 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California
Don't! I have actually come to really like the non-retractable belts in my '70. Set them once and forget about it. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/agree.gif) one of those special early car things. The retractable belts used in VW Beetles might fit. RenoRoger |
| Dominic |
Oct 14 2016, 11:53 AM
Dominic ![]() ![]() ![]() Group: Members Posts: 995 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
I retro fitted a 1970 with front retractable seat belts from a 944. There were some modifications to make it fit perfect, plus I drilled two holes in the firewall to mount the reels. Not plug and play, but it can be done.
| Elliot Cannon |
Oct 14 2016, 12:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Retractable inertia reel seat belts were designed because people are too f**king lazy to buckle and properly tighten their seat belt. They were designed more for convenience than safety. I don't trust them. Some designs will tighten the inertia reel belts automatically when the airbag is deployed. Retractable belts in the 914 however were not. Here's what I use.
| pbanders |
Oct 14 2016, 01:10 PM
This is what I'm running in my 73 DD. Which uses the later mounting points. But they should be able to come up with something for you. https://www.seatbeltplanet.com/seatbelts-an...ts/332/view/125 Perfect, that's what I was looking for, thanks. |
| ThunderbirdDrive |
Oct 14 2016, 01:32 PM
Newbie ![]() Group: Members Posts: 31 Joined: 3-March 16 From: Toronto Canada Member No.: 19,724 Region Association: Canada |
I've replaced my old belts on my '76 with new ones from seat belt planet. Extremely happy with the fit and quality of their parts.
| GeorgeRud |
Oct 14 2016, 04:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
| Dave_Darling |
Oct 14 2016, 05:32 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I believe that you must modify the firewall in order to fit the 72+ retractors on an 70-71 car.
--DD |
| raynekat |
Oct 14 2016, 06:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
I believe that you must modify the firewall in order to fit the 72+ retractors on an 70-71 car. --DD This is true. I am in the process of doing this on my 71. Grafting the recess and reinforced part of the firewall from a newer car that the retractible assemblies will fit into. Not a trivial process if done correctly. |
| pbanders |
Oct 14 2016, 06:59 PM
| 914 RZ-1 |
Oct 19 2016, 10:04 AM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
Retractable inertia reel seat belts were designed because people are too f**king lazy to buckle and properly tighten their seat belt. They were designed more for convenience than safety. I don't trust them. Some designs will tighten the inertia reel belts automatically when the airbag is deployed. Retractable belts in the 914 however were not. Here's what I use. Elliot: Where'd you get these? What's involved in installing them on a '72? |
| 914 RZ-1 |
Oct 19 2016, 10:08 AM
[quote name='pbanders' date='Oct 14 2016, 12:10 PM' post='2411181']
[quote name='cary' post='2411104' date='Oct 14 2016, 07:25 AM'] This is what I'm running in my 73 DD. Which uses the later mounting points. But they should be able to come up with something for you. https://www.seatbeltplanet.com/seatbelts-an...ts/332/view/125 [/quote] Can you confirm these will fit on a '72? I have the recess in the firewall (what I'm assuming is the later mounting points?). I have retractable seat belt now, but they stick a little and I'd like ones that work and are new. |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:50 AM |
