Where to beadblast aluminum..., ...in San Jose area? |
neo914-6 |
Apr 21 2005, 11:25 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Now that I have "time" to clean up some parts before getting my new clutch. Anyone know of anodizers?
Attached image(s) |
Mueller |
Apr 21 2005, 11:28 AM
Valley Plating, and ENS Technology are 2 companies I have used.
Both are in Santa Clara |
Dr. Roger |
Apr 21 2005, 02:09 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Hey Neo,
Great to see ya' getting your hands dirty. Is that a stage II pressure plate and clutch your using??? |
JeffBowlsby |
Apr 21 2005, 02:12 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
There is a place down on Alma, by Spartan Staduim...good bead blasters...they are not anodizers though...
You do great artwork too BTW...I hope I win.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
neo914-6 |
Apr 21 2005, 03:51 PM
Not sure, the original 8" is 2700 lb PP and I think standard bus disc. They should be available after I get my new KEP double disc and Stage II or III PP upgrade. I'd just buy a new disc. Yeah I've soiled alot of clothes these past two weeks. Have you seen my other threads? |
neo914-6 |
Apr 21 2005, 03:53 PM
Thanks for the tip and compliment. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Do you remember a name of the shop? It's closer to where I live. |
Dr. Roger |
Apr 21 2005, 04:14 PM
yep, you were so nice as to respond to a poor "wanna' be" V8 914 owner's plea for his first ride in a real V8 914..... i thought that was pretty cool of you even if yours isn't quite running yet. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) much thanks, roger |
neo914-6 |
Apr 21 2005, 04:41 PM
You have a rain check on the ride in a couple of weeks. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
I could've fixed the oil leaks, adjusted the valves, and tuned the 283 but I already had the "ready to go" 350. I did not foresee the gear drive was going to be a problem with the h/b and the clutch was the wrong size. It's good I decided to swap engines because I also found some hose fittings that were ready to leak. |
JeffBowlsby |
Apr 21 2005, 06:12 PM
You owe me...
Pacific Sandblast Svc 400 E Alma Avenue - San Jose, CA -------------------------------------------------------------------------------- 408-293-2364 |
Cap'n Krusty |
Apr 21 2005, 06:49 PM
IME, places that do bead blasting are gonna want the parts degreased before they'll even look at 'em .......... The Cap'n
Lo-Fi Version | Time is now: 6th June 2024 - 07:36 PM |
