What is this tool for? |
draganc |
Nov 5 2016, 05:38 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
bdstone914 |
Nov 5 2016, 05:53 PM
bdstone914 Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
It is for turbo tie rod installation. Are you needing a ball joint nut tool?
draganc |
Nov 5 2016, 06:50 PM
It is for turbo tie rod installation. Are you needing a ball joint nut tool? Thanks, but what is the cast nut style end for? Yes, I'm looking for a ball joint nut tool, since I want to use a torque wrench. Did find out that a 2-1/4 Dodge tool should do the job. What's your take? Also, any recommendations about the strut nut? |
McMark |
Nov 6 2016, 08:39 AM
It's for removing the stock tie rods, then reinstalling the turbo tie rods.
http://www.914world.com/bbs2/index.php?sho...239624&st=0 (IMG:http://www.914world.com/bbs2/uploads/post-5956-1405722201.jpg) |
bdstone914 |
Nov 6 2016, 08:45 AM
Yes I found the Dodge spindle nut tool. It is a littl too big so I lined it with magnetic tape to keep it centered. I use it with an impact to remove the ball joint nuts. some are rusted on so tight I have to cut them off.
Attached thumbnail(s) |
bdstone914 |
Nov 6 2016, 09:10 AM
They may have changed the design. I got mine at O'Reilly for about $12. This like shows a more simple one that does not center on the part.
http://autoplicity.com/261401-performance-...CFcOGaQodj80Fuw |
Lo-Fi Version | Time is now: 17th June 2024 - 11:59 AM |
