| tazz9924 |
Nov 6 2016, 12:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 755 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
I found these on ebay today outside of their website and was curious if they'll fit well and i guess if tires r easy to come by:
http://m.ebay.com/itm/Euromeister-Alloy-Re...%257Ciid%253A24 |
| mgp4591 |
Nov 6 2016, 01:56 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
I found these on ebay today outside of their website and was curious if they'll fit well and i guess if tires r easy to come by: http://m.ebay.com/itm/Euromeister-Alloy-Re...%257Ciid%253A24 You may want to go to the Automotion website and look under Euromeister, find out what kind of deal you can get. They also give you a 25% off over a certain dollar amount. I picked up mine at a great discount. I picked up the 17", 8s and 9s for a very reasonable price. |
| tygaboy |
Nov 6 2016, 08:33 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,790 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
Yes, they fit. Here are 7s and 9s on a friends car. You may want/need spacers. Tire availability is OK in 16". Check Tire Rack.
| bdstone914 |
Nov 6 2016, 08:40 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,271 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
QUOTE You may want to go to the Automotion website and look under Euromeister, find out what kind of deal you can get. They also give you a 25% off over a certain dollar amount. I picked up mine at a great discount. I picked up the 17", 8s and 9s for a very reasonable price. (IMG:style_emoticons/default/agree.gif) Actually call them and check the real availability. We offer the same wheels at Pelican and get them from Automotion who is out stock more than they are in stock. They report lead times of 2-3 weeks that has turned into 2-3 months and longer. Pretty good wheels for the price. |
| MikeM |
Nov 6 2016, 08:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Agree with Bruce. Very nice for the money!!
What spacers for the rear of a flared car using the 16X9"s? Mike |
| tazz9924 |
Nov 6 2016, 09:40 AM
| Steve |
Nov 6 2016, 09:51 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,026 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I'm running fixse fm10, 8 and 9, 17" wheels on mine. No spacers. Running 225 front and 245 in the rear. Mine are steel AA replica flairs. 255 rubbed in the rear unless there racing tires without the rib.
The Michelin pilot sports have a rubber rib to help prevent curb rash on the rims. |
| tygaboy |
Nov 6 2016, 10:18 AM
| tygaboy |
Nov 6 2016, 10:21 AM
Double post
| BigFour1973 |
Nov 6 2016, 10:39 AM
Member ![]() ![]() Group: Members Posts: 187 Joined: 16-November 14 From: Long Beach Member No.: 18,126 Region Association: Southern California |
I'm running fixse fm10, 8 and 9, 17" wheels on mine. No spacers. Running 225 front and 245 in the rear. Mine are steel AA replica flairs. 255 rubbed in the rear unless there racing tires without the rib. The Michelin pilot sports have a rubber rib to help prevent curb rash on the rims. Do you recall the offsets you're using on the 8s and 9s? |
| jmill |
Nov 6 2016, 12:01 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Tire availability in 16" is limited for all season radials. Your choice is BFG or Kumo. If you go with a summer tire you have a couple more options. In 17" you have many more summer options and a couple more all season options. None of them wear well in 16 or 17" but that's not a huge concern for a limited mile vehicle.
I'm at the same place you are. I have a pair of 16x7 Fuchs. Do I get a pair of 9's for the rear and have limited tire availability or go with a set of 17's which provides more tire options but doesn't look quite as good (IMHO)? |
| Steve |
Nov 6 2016, 12:57 PM
I'm running fixse fm10, 8 and 9, 17" wheels on mine. No spacers. Running 225 front and 245 in the rear. Mine are steel AA replica flairs. 255 rubbed in the rear unless there racing tires without the rib. The Michelin pilot sports have a rubber rib to help prevent curb rash on the rims. Do you recall the offsets you're using on the 8s and 9s? The 8x17 offset is 19mm The 9x17 offset is 6mm |
| tazz9924 |
Nov 6 2016, 02:18 PM
Tire availability in 16" is limited for all season radials. Your choice is BFG or Kumo. If you go with a summer tire you have a couple more options. In 17" you have many more summer options and a couple more all season options. None of them wear well in 16 or 17" but that's not a huge concern for a limited mile vehicle. I'm at the same place you are. I have a pair of 16x7 Fuchs. Do I get a pair of 9's for the rear and have limited tire availability or go with a set of 17's which provides more tire options but doesn't look quite as good (IMHO)? i totally agree about tge 16 vs 17 i found what seems like a good set of toyos on tire rack not a bad price either: https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes |
| jmill |
Nov 6 2016, 04:05 PM
i totally agree about tge 16 vs 17 i found what seems like a good set of toyos on tire rack not a bad price either: https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes That's a nice tire for the rear. It has a diameter of 24.7" and 9.7" wide. What size are you going to run on the front? I couldn't find a matching Toyo in 205, 215 or 225. |
| tazz9924 |
Nov 6 2016, 04:39 PM
i totally agree about tge 16 vs 17 i found what seems like a good set of toyos on tire rack not a bad price either: https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes That's a nice tire for the rear. It has a diameter of 24.7" and 9.7" wide. What size are you going to run on the front? I couldn't find a matching Toyo in 205, 215 or 225. likely the same i got alot of space under those flares and i have 7s on em rn |
| mgp4591 |
Nov 6 2016, 04:47 PM
I went a bit overboard... 235/45-17 in front, 275/40-17 in the rear. Yeah, I'm gonna try to make those fit. (IMG:style_emoticons/default/shades.gif)
| tazz9924 |
Nov 6 2016, 06:09 PM
I went a bit overboard... 235/45-17 in front, 275/40-17 in the rear. Yeah, I'm gonna try to make those fit. (IMG:style_emoticons/default/shades.gif) u have to keep me up dated on that whats the rear rim size ur using |
| tazz9924 |
Nov 7 2016, 04:53 PM
does anyone have any idea if 275s will fit on the rear?
| jmill |
Nov 7 2016, 06:58 PM
275/40 17 is 10.8 inches wide. I'd say you'd need to gently massage an AA metal flare out at least an inch for it to fit.
| jmill |
Nov 7 2016, 10:21 PM
Lo-Fi Version | Time is now: 18th March 2026 - 06:01 AM |
