| falcor75 |
Nov 9 2016, 03:01 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
Has anyone found as suitable Ba20s socket LED bulb to use in the foglights?
| DRPHIL914 |
Nov 9 2016, 01:23 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,889 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I asked the same question on the thread for the 914rubber LED headlights but didn't get a response. for the 75-76 ones I would think someone has done this? |
| eric9144 |
Nov 9 2016, 01:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,792 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California
Been hunting for these for a while--to the point where I'd even considered a bulk buy out of China, but dealing with China wasn't working out so well so I gave up --last piece of my LED puzzle (IMG:style_emoticons/default/popcorn[1].gif)
| Mikey914 |
Nov 9 2016, 05:19 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Let me see what I can find. I have a set of these I need to install so why not.
| bdstone914 |
Nov 9 2016, 05:37 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,264 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Let me see what I can find. I have a set of these I need to install so why not. I got one from a local FLAPS. I can pull them and see what we used. The light pattern was an issue as the small reflector bounces the light back to the big reflector and the LED was more concentrated then the original bulb. |
| 913B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Post #8018 for $14 for the pair, I bought a set too, yeah but it doesn't look OE ? but what the hell it's only $14 for LED and no wiring upgrade needed. (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/confused24.gif)
http://www.914world.com/bbs2/index.php?sho...774&st=8000 |
| Mikey914 |
Nov 9 2016, 05:59 PM
Well I'm bringng in the Late ones
| falcor75 |
Nov 9 2016, 11:57 PM
Post #8018 for $14 for the pair, I bought a set too, yeah but it doesn't look OE ? but what the hell it's only $14 for LED and no wiring upgrade needed. (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/confused24.gif) http://www.914world.com/bbs2/index.php?sho...774&st=8000 I'd prefer something that can be used with the original glass. Yeah I'm picky. (IMG:style_emoticons/default/biggrin.gif) |
| eric9144 |
Nov 10 2016, 03:47 PM
I'd prefer something that can be used with the original glass. Yeah I'm picky. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/beerchug.gif) |
| Spoke |
Nov 13 2016, 09:14 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,348 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
| Cairo94507 |
Nov 13 2016, 09:22 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,588 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Jerry I am in. Yes the fog light lens comes off the factory lights. This is one of the last exterior lights I need for my car. Wait....did you already make the warts? If not, I still need them. If you made them, I likely have them. This is what happens when a build spreads out over years. I have forgotten some of the parts I have already bought. (IMG:style_emoticons/default/beerchug.gif)
| ConeDodger |
Nov 13 2016, 10:09 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,361 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
I'd prefer something that can be used with the original glass. Yeah I'm picky. Does the glass on the stock foglight come off from the reflector? I was thinking of making an LED board to fit inside the cavity and use the original glass. You da man! Count me in too! |
| Mikey914 |
Nov 14 2016, 01:00 AM
I think the reflective dish makes the part. A flat board would not be that effective as it would not be focused.
I'm also working on new seals for these. I'll post picks with the LED bulbs installed. Attached thumbnail(s) |
| morgan_harwell |
Nov 14 2016, 09:20 AM
Ha! Finally snuck up on a camera! ![]() ![]() Group: Members Posts: 126 Joined: 28-January 03 From: Santa Cruz Mtns., Ca. Member No.: 203 Region Association: Northern California |
SOT
My non-stock 914 driving lights use H2 bulbs. Has anyone here found a LED replacement for H2 bulbs? |
| Spoke |
Nov 14 2016, 11:55 AM
I think the reflective dish makes the part. A flat board would not be that effective as it would not be focused. I'm also working on new seals for these. I'll post picks with the LED bulbs installed. Is this the 75-76 fog light? The early round one is the one I was thinking of. If I did these I would investigate using surface mount LEDs like Cree's XBD series. The XBD series are so bright the datasheet has a warning about eye injury: Vision Advisory Claim WARNING: Do not look at exposed lamp in operation. Eye injury can result. See the LED Eye Safety application note at www.cree.com/xlamp_app_notes/led_eye_safety. Using the XBD with a focusing lens like Carlco's Luxeon 10mm 10412 would give a Full Width Half Maximum (FWHM; 1/2 power angle) of about 18 degrees. This is 9 degrees off of center in all directions. There are tighter lenses available as weel For comparison, a lamp that was installed by pbanders claims 30 degree FWHM. LEDs From Amazon I used the XBDs on the first working 914 LED brake board which are in my car now. Here's a couple of pics from the first time I powered them. They were dangerously bright and I ended up cutting down the current from 300ma to 45ma for each LED. ![]() |
| eric9144 |
Apr 3 2017, 10:18 AM
Found a shop in Australia that makes an LED BA20s for the early style (round) fog lights, ordering today, will let you guys know how it goes.
| Mikey914 |
Apr 3 2017, 10:25 AM
Let us know I tried a few and the bulb didn't fit.
Lo-Fi Version | Time is now: 4th March 2026 - 07:05 PM |
