Dip Stick schick, 914-6 Dip Stick questions |
forrestkhaag |
Nov 13 2016, 11:08 AM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Does anyone know or could anyone show a picture of the correct spot on an original 914-6 dipstick to denote a "full" oil tank. And would a larger motor (than the original) change the place on the dipstick demarking a full oil dose? there is a dot pinched into the stick and three little dotts embossed below that / see pix
thanks (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
mb911 |
Nov 13 2016, 11:12 AM
914 Guru Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I prefer keeping it closer to the low line.. Engine size has nothing to do with it. The high side could cause for oil all over the. Engine compartment
PanelBilly |
Nov 13 2016, 11:19 AM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Check with the engine running
mb911 |
Nov 13 2016, 11:45 AM
wndsrfr |
Nov 13 2016, 12:44 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Check with the engine running And Hot. 9-10 quarts of oil expands a lot, so definitely shoot for the low side if it's cool. Best is to check it after a good 30 minute spirited run to get all of the oil heated up....like after a DE session! (IMG:style_emoticons/default/driving.gif) |
gandalf_025 |
Nov 13 2016, 06:03 PM
Senior Member Group: Members Posts: 1,456 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
This is the dip stick on my 70-6
looks like this.. |
forrestkhaag |
Nov 13 2016, 06:19 PM
yes / that is the one I have but not so clear as to the line marking the oil level / is that the low level mark mentioned above?
gandalf_025 |
Nov 13 2016, 06:34 PM
Only 1 line on mine... no dimple on it either..??
porschetub |
Nov 13 2016, 07:18 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
yes / that is the one I have but not so clear as to the line marking the oil level / is that the low level mark mentioned above? Depends what tank you have ,I have proved the marks on the PMS filler/dipstick are useless on a stock tank,maybe ok with their alloy one. I'am running 8 litres of oil with is over the factory level but I have upgrade filter (OC 61 ) and I have larger hoses and lines,that should be more than enough and I only get a 20mm on the PMS dipstick (IMG:style_emoticons/default/dry.gif) ,way below the bottom mark. Thinking maybe the 914rubber one is a better option...don't know |
fixer34 |
Nov 13 2016, 07:25 PM
Senior Member Group: Members Posts: 1,089 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Mine (3/70) looks the same as the first pictures.
There was another thread going a while back similar to this. ALWAYS check the oil level with it hot (or at least warm) and the engine running. As soon as you shut the engine off, oil will seep back into the engine sump. By the time it's cold, it could be a quart or more. You can very easily overfill the tank. |
rudedude |
Nov 13 2016, 08:02 PM
Senior Member Group: Members Posts: 511 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I've always used the 2notches on the bottom as my lower level on 3different 6 cylinder Porsches and have never had any issues
wndsnd |
Nov 13 2016, 08:09 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
All depends on tank you have, filler neck you have, and stick you have. Not easy,. But the oil does expand alot when up to temperature so I agree, once you have verified what your system is, stick with the lower side, or you will get messy in there.
wndsnd |
Nov 13 2016, 08:12 PM
All depends on tank you have, filler neck you have, and stick you have. Not easy,. But the oil does expand alot when up to temperature so I agree, once you have verified what your system is, stick with the lower side, or you will get messy in there. Sorry I missed you were asking about an original six. Gandalf and others can help. |
johnhora |
Nov 13 2016, 08:32 PM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Mikey914 |
Nov 14 2016, 12:38 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The original 6 dipstick I coped didn't have a max mark on it. Perhaps a 911 one?
http://www.914world.com/bbs2/index.php?sho...914/6&st=25 |
rudedude |
Nov 14 2016, 09:29 AM
forrestkhaag |
Nov 14 2016, 10:24 AM
As I bought an original 6 tank, filler neck on it and cap with dipstick therein, I am curious to know the measured length of your 914-6 verses 911-6 length is.... / That information will tell me what i am sticked with...
rudedude |
Nov 14 2016, 11:38 AM
/6 13 1/16"
911 11 13/16" |
Mikey914 |
Nov 14 2016, 11:33 PM
As I bought an original 6 tank, filler neck on it and cap with dipstick therein, I am curious to know the measured length of your 914-6 verses 911-6 length is.... / That information will tell me what i am sticked with... (IMG:style_emoticons/default/beerchug.gif) This looks like the correct 6 dipstick |
IronHillRestorations |
Nov 15 2016, 07:07 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Put 9 quarts of oil in the system and check the level with the engine running and the car on a flat level spot, before it gets up to operating temp, I'd consider that oil level to be the bottom mark. Note the level and mark the dipstick accordingly. Add another quart and that's your top mark. If you have an external oil cooler you need to add that amount of oil capacity to the 9 quarts.
Lo-Fi Version | Time is now: 9th June 2024 - 02:56 PM |
