Quick question about torsion bar adjustment |
patssle |
Nov 13 2016, 08:58 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
To raise the car height do you turn the torsion bar adjusting bolt clockwise or counter-clock wise?
infraredcalvin |
Nov 13 2016, 09:23 PM
Distracted Member Group: Members Posts: 1,528 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Clockwise. Tightening will raise the car, loosening will lower. If you don't get it high enough you'll need to reindex the bars to get them how you want.
Rand |
Nov 13 2016, 09:26 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Don't sweat it. It's just a bolt and when you look at it, it will be obvious. Mark where you started and if handling is important to you, a corner balance may be necessary if you make significant changes.
flat4guy |
Nov 25 2016, 01:00 AM
Member Group: Members Posts: 444 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
I am guessing this is for the front only, do you have a pic where the bolt is or is it obvious?
mgp4591 |
Nov 25 2016, 02:39 AM
914 Guru Group: Members Posts: 5,382 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I am guessing this is for the front only, do you have a pic where the bolt is or is it obvious? It's at the rear of the torsion bars and it really isn't hard to find, pretty obvious. The rear height adjustment varies on the shock/spring assy, but it's usually an external snap ring that fits into the shock body below the spring perch. When you reinsert it up or down into a new slot the spring pressure will change, thus changing the the ride height. You want to be careful before reorienting the rear springs - there's a lot of stored energy in those puppies and it's easy to get, uh, surprised. There's a few different ways to make it safe so if you need to do it, ask around. Always someone here ready to help! |
porschetub |
Nov 25 2016, 12:51 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Just done mine all round ,front is 16mm of thread at the bottom of the adjuster (alloy front beam),rear is 5th clip groove up on the Bilsteins with 100lb springs.
It sits nice and still has good ground clearance,found the ride overly firm with the car higher as it was. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:04 PM |
