Short shifter, WTB short shifter |
rgalla9146 |
Nov 19 2016, 12:15 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
WTB Weltmeister (or ?) short shift lever for a side shift trans.
Only need the lever with the lengthened lower part attached or the lower part separately. TIA Rory |
gms |
Nov 19 2016, 03:07 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
By now you have probably realized what a rare and coveted piece of Porsche history these parts represent. I am willing to trade you even up for a set of Factory GT flares.
toolguy |
Nov 19 2016, 05:25 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Cut 3 inches off the top of the stock shifter. Does the same thing.
rgalla9146 |
Nov 19 2016, 06:29 PM
Cut 3 inches off the top of the stock shifter. Does the same thing. Curious you should say that. Great idea. For me the lever is already too far away so three inches off will only make the situation worse. I need the seat all the way back. The car in question is a hotrod anyway. I'll shorten the lever and move the whole shift console to the rear ! Walla ! Or some combination of the above |
toolguy |
Nov 20 2016, 08:23 AM
I have found {on the 914's I've had} that there is enough spline on the shift rod adjustment to slide the rod out which makes the lever come rearward. For me it was having to lean forward to push the long stock lever into R-2-4th Cutting the lever and sliding the spline fixed that. .
914forme |
Nov 20 2016, 08:57 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Also if you use the Tangerine shift adjuster you can get a 20% reduction in throw with the stock shifter. Added bonus you get more precision adjustment of the shifting so you can tun it up.
You could also have a bar splined and shortened if you wanted to pull it back a few inches. Other options to recurve the shifter. Or drop an extension handle on it and pull it back. Takes away from the stock look though. I would think you could bend the shifter just a bit and no one would ever know until they got in and not the shifter in a farther back position than you wanted. Trail and error method. Rais the front of the shifter base with a spacer. Washers work good for testing. This brings the shifter back toward you a bit. Extend the rod out as fat as you can in the coupler and be safe. Rotates the rod back towards you more. Moving the knob back. And then make sure you can still get to R 2 4. More than likely you will run out of shifter movement in the ball and cup before you do rod. If you need more rod, lengthen it. Once you have the spacers set. Measure the total stack, get a spacer made. I would gladly make one for your Minilites (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/av-943.gif) The spacer is easy, gladly make you one if you need me to. You will just need longer bolts. You could also raise the back if you need the shifter up to make up for a cut in length. I don't think you can make up for a 3" cut though. WeltMeister kit might have been 1/2 -1 inch max. I have not had once since the early 2000s You could also machine the shifter housing to pull it back, tilt the socket, and then raise the front and rears etc.... Much deeper discussion. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:02 PM |
