Installing Defroster Vents, How do they attach |
Mowog4 |
Nov 21 2016, 09:55 AM
Member Group: Members Posts: 291 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I am putting together my car, looking for advice on how the defroster vents attach in the car. Any help is appreciated.
Thanks Ed |
malcolm2 |
Nov 21 2016, 10:14 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
If you are putting it BACK together, then you have it APART. Seems when I was doing that, I had to do everything 2 or 3 times 'cause I forgot to install 1 thing... (IMG:style_emoticons/default/piratenanner.gif)
It has been some time since I had my vents out, but IIRC with all the dash stuff out of the front trunk, they connect to the, i'll call it a control box. It has all the cables that direct the air. a small round clip goes around the little tit (red circle). one on the box, one on the vent. might be one on both sides of the opening where the couple. So the top wedges in under the window and the bottom is attached to the control box. You might be missing the little tit. oh yeah, don't forget the foam seal that goes on the wide funnel. AA and probably 914rubber sell them. |
Mikey914 |
Nov 21 2016, 12:23 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We both sell them. I use a slightly denser foam.
http://www.shop.914rubber.com/Defroster-se...m?categoryId=-1 |
Mikey914 |
Nov 21 2016, 12:26 PM
Not easily seen but you can see the area the little ring clamps go.
Also have the hoses if you need them Attached image(s) |
iankarr |
Nov 21 2016, 01:13 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Mine were super brittle. One broke in my hands and I needed to buy a replacement. Be careful handling them...and putting the clamp on!
Lo-Fi Version | Time is now: 6th June 2024 - 02:42 AM |
