thomasotten |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,565 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 ![]() |
I am curious as to what kind of oil cooler setup is required or recommended
when installing a stock 74-77 2.7 911 engine. Use stock t-stat control valve, stock cooler? Any past experience would be appreciated. |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,892 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
I am curious as to what kind of oil cooler setup is required or recommended when installing a stock 74-77 2.7 911 engine. Use stock t-stat control valve, stock cooler? Any past experience would be appreciated. They run hot. I used a mocal oil thermostat with a Gt front oil cooler and shroud. Check out patrickmotorsports.com for pictures and more information. |
db9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None ![]() ![]() |
Do a search for Mike Fitton here. I believe he has an original -6 that has been running a 2.7 for a while with just the stock "on-engine" cooler. He may be able to provide another data point.
mountainroads |
Member ![]() ![]() Group: Members Posts: 210 Joined: 19-February 12 From: Seattle Member No.: 14,145 Region Association: Pacific Northwest ![]() |
This question comes up occasionally, and I pay attention when it does because I have similar concerns. I can only provide personal experience:
My original -6 also has a 2.7 engine with only the stock, in-engine cooler. The oil temp has never moved into the uncomfortable range, even with most of the driving done on the hotter, drier side of the mountains from where I live. That's with "spirited" driving and it can get pretty warm over there in the summer. The engine is currently in for a refresh. Previously running unknown spec cams ("Solex" was the closest approximation when inspected.) They provided great bottom-end, but petered out a bit at the top. Now running modern, "modified-S". We'll see if that'll make a difference. - MR |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,610 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
My 2.7 ran got until I put a front oil cooler in. I would highly recommend it. I am going to run one on my 2.4 s engine build.
Mike Fitton |
Senior Member ![]() ![]() ![]() Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest ![]() ![]() |
Do a search for Mike Fitton here. I believe he has an original -6 that has been running a 2.7 for a while with just the stock "on-engine" cooler. He may be able to provide another data point. Here I am. Yes running a 2.7 in my original 914-6 with stock engine cooler with no problems, what better test than 11 hours each way to Okteenerfest at above posted speed limits. (IMG:style_emoticons/default/driving.gif) PS: Original matching engine is going back in after rebuild. |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,454 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
I am curious as to what kind of oil cooler setup is required or recommended when installing a stock 74-77 2.7 911 engine. Use stock t-stat control valve, stock cooler? Any past experience would be appreciated. Key is if you will be running it on track. Half hour DE's put a lot of heat into that 8 quarts of oil & you'll need the front cooler. If only street driving you're prolly OK with stock. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,885 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
There are other factors to consider,is the motor clean and oil free,how is the fit of the engine tin,are all the holes (unused) in the enginebay sealed up,are the sealing rubbers around the engine in good condition,and theres more.
These issues could be the difference between it running a good oil temp or running hot. A few on here have had some success running coolers fan assisted near the gearbox,how good I don't know. Problem is that the 2.7 is the last motor you want to constantly overheat (IMG:style_emoticons/default/sad.gif) . |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
yeah its not a problem until it is ..lotta good points Ptub...those little flapper/defuser things under the car help with exspelling heat from under the car.I plan to add those and modify the valance with some holes ,motor temp went up 6-10 degrees when the original valance was put back on...good luck
(IMG:style_emoticons/default/smile.gif) |
Steve |
Depends where you live. I did not have problems on the freeway. My problem was stop and go traffic in the summer. I added fans to pull air through the cooler when stuck in traffic.
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
I've been running a hot-rod 2.7 in my 914-6 conversion for many years, but did originally install a front oil cooler, thermostat, and AN12 braided lines to hook everything together. Though they may live without an external cooler, I didn't want to take any chances. Since I used to do driving school/ track events, the 2.7 would get hot, even with a front cooler. However, it never got to be 'stupid hot'.
I'd vote for a front cooler to help the 2.7 stay together. The only reason that Porsche didn't put them on 2.7 when they were originally manufactured is that we had a 55 mph speed limit at the time and they thought they could get away without one ( and then save money). Lots of pulled head studs proved that it was a false economy! |
billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,408 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States ![]() |
I have a 2.7 in a '72 914. The car is only driven on the street (no track) and I haven't had any issues using just the stock oil cooler.
patssle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None ![]() |
I have a 3.0L and tried to get away without a 2nd oil cooler but the temps kept rising. Couldn't do extended basic freeway driving and I pulled over at 250.
rudedude |
Senior Member ![]() ![]() ![]() Group: Members Posts: 521 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest ![]() ![]() |
Mine never gets over 230 in hot weather. Has a small cooler next to tranny with thermostat fan on it. Do wish it was a little cooler.
6freak |
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
My 2.7 only hit 220 a couple of times mid-summer on the highway. Mostly it runs 180.
Stock engine mounted cooler. Recently I regeared a little lower so the engine revs higher on highway. Will be interested if that helps next summer but around here it is 40 degrees out these days. |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
My 2.7 build is getting a Patrick/Setrab cooler.
Why take chances? |
CMONNETT |
Member ![]() ![]() Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region ![]() |
Thomas,
You will need an additional cooler where we live. Chris |
porschetub |
Interesting reading,many without additional coolers and no problems, these are real world examples ,a lot would depend on the ambient temp and the RPM range the car is driven in,I'am still learning to drive mine but I find that driving a gear lower keeps the engine more "on the boil" the motor I have is hardly what you would call torquey.
Had a spirited drive yesterday back from my friends shop after some tidy up work on the motor,fairly hot day and mostly 180 on the flat road with the temp going to 185 on the hilly twisties. Then there the issue of me learning to drive a lefthand drive car on our roads but that's another story....... |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,587 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
I'm going to try the setrab with dual fans under the rear trunk on my car...if that doesn't work I'll have to suck it up and do a front cooler (don't really want to cut up the front trunk).
Lo-Fi Version | Time is now: 15th July 2025 - 04:09 AM |
