| ricardo |
Dec 4 2016, 09:07 AM
Newbie ![]() Group: Members Posts: 47 Joined: 9-November 16 From: Lakeview, NY Member No.: 20,572 Region Association: North East States |
Finally got engine running but I suspect vacuum leaks. Was wondering what the best way is to detect vacuum leaks without a smoke machine? Mi hu
| Frankvw |
Dec 4 2016, 04:27 PM
working on my first 914 ! ![]() ![]() ![]() Group: Members Posts: 653 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
for example with a vacuum tester tool. You can find them under 20 bucks which will be fine to test the hoses. You create a vacuum pumping air out while the other side is plugged and watch the gauge if you keep or loose the vacuum. you can also buy (instead of a tool) 20 bucks worth of vacuumhoses and replace the old ones.20 bucks will not be enough to replace them all. Keep in mind you cannot just use any hose for the stronger-vacuum ones.... good luck! |
| ottox914 |
Dec 4 2016, 04:36 PM
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Do you like cigars? They make excellent smoke machines.
You can use a propane torch, unlit, set to a low flow rate to hold in the areas you think you have a leak. RPM's go up, you found your leak. |
| pete000 |
Dec 4 2016, 04:46 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I made a smoker out of a paint can. Lots of how to do videos on You Tube. They also sell them on ebay if you don't have the time.
| cary |
Dec 4 2016, 09:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
I made a smoker out of a paint can. Lots of how to do videos on You Tube. They also sell them on ebay if you don't have the time. What Pete said. Easy deal ..................... I built mine for a leak investigation on a 4.0 Ford. But we'll rework it for testing D-jets when we finish up Mark and Mike's engines. |
| bdstone914 |
Dec 4 2016, 10:05 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,375 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Or use a water spray bottle and squirt suspected area. Idle will drop when it sucks in water.
Lo-Fi Version | Time is now: 11th September 2026 - 02:22 AM |
