oil pump cover nuts, do you have to use the sealing kind? |
iankarr |
Dec 14 2016, 12:25 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
Trying to make good on my new years resolution to stop leaks on my 2056. I replaced the oil pump cover gasket (it was partially disintegrated). In Jake's DVD, he recommends using the red sealing-type nuts on the oil pump cover. Looks like they're still available from air-cooled....but are they the only way to go? Or can I use something like teflon paste on the studs? Thanks! Ian |
McMark |
Dec 14 2016, 12:48 PM
Nope, never use them on any of my builds and they weren't spec'd from the factory.
iankarr |
Dec 14 2016, 02:06 PM
Thanks, Mark. Do you use teflon or anything else to keep oil from seeping past the threads? It's under pressure, no?
McMark |
Dec 14 2016, 02:16 PM
It's only under pressure if the rest of the seal leaks. Which is a more complicated way of saying, No, it's not under pressure. I don't put sealant on the threads. But you can if you want. It's not gonna hurt anything.
iankarr |
Dec 14 2016, 02:18 PM
Ah. Makes sense. Thanks!
Lo-Fi Version | Time is now: 9th June 2024 - 04:49 PM |
