weird wiring question |
tazz9924 |
Jan 19 2017, 10:26 AM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
ok so. Since ive owned my 914 my turn signals haven't worked at night (running lights on), if i pull the hazards, the switch stays illuminated red no flashing. the minute i turn off the running lights it works perfect, turn signals included. two days ago my turn signal randomly stop workin (day and night), hazards included (the hazards light still stays illuminated when the lights are turned on though). Ive tried figuring it out prior but to no avail. Any ideas?
IronHillRestorations |
Jan 19 2017, 01:15 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Probably a relay, or the wrong relay
falcor75 |
Jan 19 2017, 01:21 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Take the fuse panel down and check the relays and their connections would be my first guess.
914dave |
Jan 19 2017, 01:48 PM
914 Addict Group: Members Posts: 703 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
I agree. Relay problem.
Beebo Kanelle |
Jan 19 2017, 05:16 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Check all you ground connections too!
tazz9924 |
Jan 19 2017, 05:26 PM
Which relay would it be also where are the ground connections for it
Dave_Darling |
Jan 19 2017, 06:37 PM
The flasher relay is one of the ones on top of the fuse panel. It is usually a square, as opposed to the standard round relays. Double-check the wire colors running to it versus the wiring diagram to make sure you've got the right part.
The fact that the flashers work with the parking lights off but not with them on makes me think that the turn signal buckets (either front or rear or both) are wired incorrectly. If the parking light power were switched for the ground, for instance, you could get behavior like that. --DD |
Lo-Fi Version | Time is now: 9th June 2024 - 03:58 PM |
