WTB: 911 2.4 S (or S-like) cams for my 2.7 build |
JmuRiz |
Feb 8 2017, 02:05 PM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I'm looking for a set of 3-bearing S-grind or similar cam (Mod-S, etc) for my 2.7 build ('74 7R case).
I was going to use 3-lobe SC grinds I bought a while back and keep the stock pistons if they looked OK, digging into the motor it needs a full build, so I'm going 9.5:1 pistons, re-coated cyls etc etc. Need hotter cams to match the new p/c I wanted to check here before contacting Dougherty/Elgn/WebCam Thanks, |
mepstein |
Feb 8 2017, 02:33 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Talk to the cam guys. There's been developments in the last 40 years since the S cams were made.
mb911 |
Feb 8 2017, 02:51 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Solex cams work well if using carbs.
Luke M |
Feb 8 2017, 05:37 PM
Senior Member Group: Members Posts: 1,373 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I'm looking for a set of 3-bearing S-grind or similar cam (Mod-S, etc) for my 2.7 build ('74 7R case). I was going to use 3-lobe SC grinds I bought a while back and keep the stock pistons if they looked OK, digging into the motor it needs a full build, so I'm going 9.5:1 pistons, re-coated cyls etc etc. Need hotter cams to match the new p/c I wanted to check here before contacting Dougherty/Elgn/WebCam Thanks, Did you already buy a set of p/c's ? Like stated solex cams are better if running on the street. |
raynekat |
Feb 8 2017, 06:26 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
With the larger 2.7 displacement, std S cams work fine in my experience.
I had a set of Solex cams on my RS spec motor (8.5:1) by mistake. When I finally got the correct stock S cams installed, it was a totally different animal. It was fine around town and a beast on the track. The car had MFI induction in case that matters. I'm building another one of these 2.7 MFI motors soon. It will be higher compression (~9.5:1) and I'll look into the S mod cams from Dougherty. At about $900/pair, they're not inexpensive. It is still going into a street car. "Your mileage may vary" |
mlindner |
Feb 9 2017, 06:46 AM
Senior Member Group: Members Posts: 1,525 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Nathan, my 2.2 has S cams, but E heads so I need to go to Solex. I could pull them in a month or so. Taking off to Florida next week. I could take a few pictures for you. Best, Mark
bob |
Feb 10 2017, 07:04 AM
Member Group: Members Posts: 146 Joined: 8-January 03 From: Va. Member No.: 109 Region Association: None |
I have a set of 3-bearing MOD S cams if you're interested. (I'm in NOVA)
-bob |
Lo-Fi Version | Time is now: 31st May 2024 - 06:40 PM |
