gcrotvik |
Member ![]() ![]() Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest ![]() |
I need a throttle bell crank for my 914/6 trans/6 conversion. I have one but it's bent and pretty much worn out. I looked on the Mittelmotor site but came up empty. I put a WTB in the classified section several months back but no answer (as expected!)
Does anyone know of an alternate source for part number 91442302501? Thanks, Greg |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Do you need the original part? I believe that Rich Jonson (a914guy) makes a functional replacement, but I'm not sure how exact a replacement it is. Shoot him a PM and ask.
--DD |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,829 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Rich Johnson has made those in the past, I'm not sure if he still does
gcrotvik |
Thank you both!
Greg |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,188 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Double check with Porsche. I think they had some made up.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Is this for a real six trans? with the pin already on the case?
I believe RJ's is for a conversion of a /4, the bell crank might not fit. You can take a 911 bell crank which is correct except for the arm isn't in the right spot. It's brazed on so if you're careful you can heat it cherry red hot, then quickly spin it to the correct orientation. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,958 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I used an RJ conversion with an intermediate plate from a 911. Works great. Fits on the stock stud. Rich's piece does come with an adaptor so it bolts on to a 914 case without mods.
Attached thumbnail(s) ![]() |
gcrotvik |
gcrotvik |
Is this for a real six trans? with the pin already on the case? I believe RJ's is for a conversion of a /4, the bell crank might not fit. You can take a 911 bell crank which is correct except for the arm isn't in the right spot. It's brazed on so if you're careful you can heat it cherry red hot, then quickly spin it to the correct orientation. It's for a real 914/6 trans that has the boss in the intermediate plate. Good suggestion on modifying the 911 bell crank. |
forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
I just installed the RJ assembly and it is a perfect fit. Easy install as well. And yes, he has them for sale among other finely crafter conversion parts.
Cheers |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,252 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Adding another alternative to the mix, PMS makes a longer throttle cable for /6 conversions that doesn't need the linkage at all.
It simply loops around and goes straight to the throttle body. I used this for my 3.6L ... (IMG:style_emoticons/default/bye1.gif) |
SirAndy |
Adding another alternative to the mix, PMS makes a longer throttle cable for /6 conversions that doesn't need the linkage at all. It simply loops around and goes straight to the throttle body. I used this for my 3.6L ... (IMG:style_emoticons/default/bye1.gif) You can see the black throttle cable to the right looping up through the opening in the sheet metal and to the throttle body. (IMG:style_emoticons/default/driving.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1185423324.jpg) |
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Found this nice piece just today on Ebay.
The curved throttle linkage from the bell crank up to the engine. http://www.ebay.com/itm/New-Genuine-Thrott...SWF&vxp=mtr |
mepstein |
Found this nice piece just today on Ebay. The curved throttle linkage from the bell crank up to the engine. http://www.ebay.com/itm/New-Genuine-Thrott...SWF&vxp=mtr I think they sell for less from others. |
raynekat |
Checked with my local dealer....only $45. So Ebay not a great deal.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,031 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I have several 911 ones that could be modified to make them into 914-6 ones.
1TRICK6 |
Newbie ![]() Group: Members Posts: 45 Joined: 13-July 11 From: Southern California Member No.: 13,313 Region Association: Southern California ![]() |
Lo-Fi Version | Time is now: 8th July 2025 - 04:08 PM |
