Koni Shock base adjustment setting |
tazz9924 |
Feb 22 2017, 05:20 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Ok so, Im doing a 5 lug conversion with koni struts and im at the point before i have to put it in and i have to set the shocks rebound stiffness. Im gonna be doing autocross and even track days in this car so i was thinking of 1/2 to 3/4 of full adjustment stiff or 1-1.5 full turns. Is there an ideal setting for a 914 or is the setting: Just wing it
messix |
Feb 22 2017, 06:58 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
is this a red or yellow shock?
tazz9924 |
Feb 22 2017, 07:44 PM
Krieger |
Feb 22 2017, 09:25 PM
Advanced Member Group: Members Posts: 4,731 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I think there are a lot of things you have to consider. Sway bar/s, spring rates front and rear, tires, tire pressure, driving style, alignment. My car has a 22mm weltmeister front bar, stock fromt torsion bars, 140# rear springs, 205/55/16. For autocross I only adjust my reds in the front to full hard. The rears are always full soft. Get out and drive it. Talk to the instructors or the gear heads that work on the cars when your there. Have people observe how you car looks when it's on the track. Make one change at a time. Keep going back and have fun!
bdstone914 |
Feb 22 2017, 09:30 PM
bdstone914 Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Try it at about 3/4 firm as a starting point. See how it works and adjust according. For street setting 1/2 way is suitable to most drivers.
forrestkhaag |
Feb 23 2017, 10:42 AM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Agreed as to Bruce's suggestion / He sold me a pair of reds way back when and we set them in his shop / Ride is firm and flat in the corners but tolerable by my lovely wife's decerning requirements for ride comfort.
Randal |
Feb 23 2017, 05:02 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I think there are a lot of things you have to consider. Sway bar/s, spring rates front and rear, tires, tire pressure, driving style, alignment. My car has a 22mm weltmeister front bar, stock fromt torsion bars, 140# rear springs, 205/55/16. For autocross I only adjust my reds in the front to full hard. The rears are always full soft. Get out and drive it. Talk to the instructors or the gear heads that work on the cars when your there. Have people observe how you car looks when it's on the track. Make one change at a time. Keep going back and have fun! All good advice. It would really help to see the car in a hard cornering situation. Post a picture. (IMG:style_emoticons/default/biggrin.gif) Also turn-in and understeer, especially on tight corners, can be controlled by using a torque bias differential. Huge difference can be realized. Are you mostly doing autox or track as well? |
rhodyguy |
Feb 24 2017, 09:21 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Are your konis the externally adjustable, white knob on the top, or the internally, you compress them and turn the shaft, version? For the later I would suggest a medium setting. PITA to change the setting. Full/mostly hard for a primarily street driven car in Tacoma is going to be miserable.
tazz9924 |
Feb 24 2017, 11:52 AM
Are your konis the externally adjustable, white knob on the top, or the internally, you compress them and turn the shaft, version? For the later I would suggest a medium setting. PITA to change the setting. Full/mostly hard for a primarily street driven car in Tacoma is going to be miserable. agreed even stock suspension isn't enough to cope with the stupid brick road hills of downtown |
Lo-Fi Version | Time is now: 16th June 2024 - 11:14 PM |
