oil leak from flywheel bolts, do I need thread sealant here? |
davesprinkle |
Mar 15 2017, 01:30 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
My type 4 engine is leaking oil via the threads of the flywheel bolts. How does this leak-path get sealed?
6freak |
Mar 15 2017, 02:26 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
Mark Henry |
Mar 15 2017, 02:41 PM
There is an O-ring in the flywheel where it mates to the crank, it's missing or damaged.
Many don't realize that for a T4 RMS repair there's 2 seals, the RMS and the flywheel O-ring. |
Mark Henry |
Mar 15 2017, 02:45 PM
This is a T1 flywheel but the O-ring is installed the same way.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.aircooledtech.com-26-1489610753.1.jpg) |
6freak |
Mar 15 2017, 02:52 PM
There is an O-ring in the flywheel where it mates to the crank, it's missing or damaged. Many don't realize that for a T4 RMS repair there's 2 seals the RMS and the O-ring. I didn't! I don't see how that stops oil if it mates direct to the crank.... almost seems more like a harmonic dampner ..ill be in one soon and ive got more reading to do |
Mark Henry |
Mar 15 2017, 03:13 PM
The RMS is under direct pressure from the #1 main bearing, the slightest scratch in the flywheel or crank mating surfaces will act like an oil galley.
One of the reasons not to use too much sealant on case halves is so you won't clog the RMS/rear main bearing oil drain notch. Clog that relief notch and the best seal in the world won't stop the oil coming out of the RMS. |
6freak |
Mar 16 2017, 07:17 AM
The RMS is under direct pressure from the #1 main bearing, the slightest scratch in the flywheel or crank mating surfaces will act like an oil galley. One of the reasons not to use too much sealant on case halves is so you won't clog the RMS/rear main bearing oil drain notch. Clog that relief notch and the best seal in the world won't stop the oil coming out of the RMS. you learn something new everyday (IMG:style_emoticons/default/smile.gif) but that O ring has nothing to do with keeping the oil in the motor ...maybe I`m just missing it surprise (IMG:style_emoticons/default/laugh.gif) ...ill have to dig into the book more |
Montreal914 |
Mar 16 2017, 07:52 AM
Senior Member Group: Members Posts: 1,588 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
RMS seals around the neck of the flywheel, not on the crankshaft itself.
The O-ring inside the flywheel seals it to the crankshaft. |
Mark Henry |
Mar 16 2017, 10:37 AM
The RMS is under direct pressure from the #1 main bearing, the slightest scratch in the flywheel or crank mating surfaces will act like an oil galley. One of the reasons not to use too much sealant on case halves is so you won't clog the RMS/rear main bearing oil drain notch. Clog that relief notch and the best seal in the world won't stop the oil coming out of the RMS. you learn something new everyday (IMG:style_emoticons/default/smile.gif) but that O ring has nothing to do with keeping the oil in the motor ...maybe I`m just missing it surprise (IMG:style_emoticons/default/laugh.gif) ...ill have to dig into the book more Remove your flywheel O-ring and report your findings...they should be easy to spot on your garage floor. (IMG:style_emoticons/default/biggrin.gif) RMS seals around the neck of the flywheel, not on the crankshaft itself. The O-ring inside the flywheel seals it to the crankshaft. Exactly. (IMG:style_emoticons/default/smile.gif) Just in case your argument is a /6 engine doesn't have a O-ring, it has a main bearing thrust surface that acts as a slinger, much like in a VW T1 crank on the pulley end. The oil gets slung off into the case before it gets to the RMS. This is a common mistake that I've seen since I started wenching on these in the 80's, really I've known about this since watching my brother wrench on them in the 70's. |
6freak |
Mar 16 2017, 02:51 PM
The RMS is under direct pressure from the #1 main bearing, the slightest scratch in the flywheel or crank mating surfaces will act like an oil galley. One of the reasons not to use too much sealant on case halves is so you won't clog the RMS/rear main bearing oil drain notch. Clog that relief notch and the best seal in the world won't stop the oil coming out of the RMS. you learn something new everyday (IMG:style_emoticons/default/smile.gif) but that O ring has nothing to do with keeping the oil in the motor ...maybe I`m just missing it surprise (IMG:style_emoticons/default/laugh.gif) ...ill have to dig into the book more Remove your flywheel O-ring and report your findings...they should be easy to spot on your garage floor. (IMG:style_emoticons/default/biggrin.gif) RMS seals around the neck of the flywheel, not on the crankshaft itself. The O-ring inside the flywheel seals it to the crankshaft. Exactly. (IMG:style_emoticons/default/smile.gif) Just in case your argument is a /6 engine doesn't have a O-ring, it has a main bearing thrust surface that acts as a slinger, much like in a VW T1 crank on the pulley end. The oil gets slung off into the case before it gets to the RMS. This is a common mistake that I've seen since I started wenching on these in the 80's, really I've known about this since watching my brother wrench on them in the 70's. copy copy no argument here! like I said I've got some reading to do, no better place to come when I get stumped then here though... I know that much Thanks (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:30 PM |
