Welding in rear sway bar stiffening plate in trunk ? |
cary |
Apr 6 2017, 08:33 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Does anyone have a shot of the correct weld in of the rear sway bar stiffener plates in the trunk ? Most of the time they're covered over with seam sealer. After I weld in the rosettes I'd like to complete the welds as the factory did it. On Matt's car thats on the lift they look like 3/4" seams on all 4 corners, so 8 welds. Plus the 5 rosettes.
Moonlighting at MiddleMotors. Matt on the blast cabinet. Super In Law tearing down Matt's rear suspension. Me burning metal on Doug's car. (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/cheer.gif) |
raynekat |
Apr 7 2017, 01:47 AM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Cary, found this on Pelican Parts:
http://www.pelicanparts.com/techarticles/9...4_rear_sway.htm with their pic. You're in the ball park for sure. |
raynekat |
Apr 7 2017, 01:54 AM
Couple more pics I found on-line from the same car.
Rear part of trunk floor removed, but cut around the sway bar mount/reinforcement. After replacing the pan and priming. |
jmitro |
Apr 7 2017, 06:44 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
on my 74 they were spot welded in place, no seam welds and no seam sealer
Mark Henry |
Apr 7 2017, 07:03 AM
It's been quite a while since I did mine but doesn't the factory mount have a step in it? (IMG:style_emoticons/default/confused24.gif)
gcrotvik |
Apr 7 2017, 07:12 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
on my 74 they were spot welded in place, no seam welds and no seam sealer This is OE correct. Both of my 74's have 6 spot welds, one in each corner, 2 in the middle on each plate. I added a photo below. This is a great Garage link. It details a very original 73 2.0: http://www.914world.com/bbs2/index.php?showtopic=256832 It's great for reference. Attached image(s) |
cary |
Apr 7 2017, 07:55 AM
Then it's done. Other than a quick buzz with the mini flapper that I did after the picture was taken.
Thanks for the input. I just wanted a second opinion to compare to what I had here in the shop. Beings that it was different than the Pelican shot. Thanks. |
Dave_Darling |
Apr 7 2017, 08:33 AM
It's been quite a while since I did mine but doesn't the factory mount have a step in it? (IMG:style_emoticons/default/confused24.gif) The part that's under the trunk floor does. The reinforcement on the top does not. --DD |
Lo-Fi Version | Time is now: 8th June 2024 - 04:32 AM |
