Transmission output shaft seal |
914itis |
Apr 16 2017, 06:16 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
What's the secret with that ?
Last year at Hershey , one came out that I replaced. I replaced them again with brand new seal from pelican, leak again. no scratched on the surface and surface is clean. Seals are tight. Do you push them Althea way against the bearing or flush with the outside perimeter? |
BeatNavy |
Apr 17 2017, 06:55 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
What's the secret with that ? Last year at Hershey , one came out that I replaced. I replaced them again with brand new seal from pelican, leak again. no scratched on the surface and surface is clean. Seals are tight. Do you push them Althea way against the bearing or flush with the outside perimeter? Paul, I am pretty sure those seals are supposed to sit slightly below flush with the outside, but there is some tolerance. There is a lip on the inside, and I think ideally they sit against those. But you don't want them so deep that they sit against the bearing. I would just make sure the mating surfaces, including the output flange surfaces, are as clean as possible. |
Krieger |
Apr 17 2017, 07:57 AM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Why don't you check the vent on top of the trans case. Make sure it flows air. I put the trans seal in dry. Also, very important, make sure the pilot bearing in the flywheel is intact. If there is no bearing in there the shaft will flop around and cause a leak.
914itis |
Apr 17 2017, 08:13 AM
I did some digging on the pelican site and came up with the culprit. its not leaking on the seal, the oil id from the breather port and going down the axle. you are right Krieger
the orientation of the vent port is important. it should ne at 2'ocklock facing the back of the car. I just verified that it was not, I will update the post once I test the car. |
Krieger |
Apr 17 2017, 08:35 AM
Check the Haynes Manuel. It has a picture for proper orientation. IIRC it points towards the passenger seat. I think 45*off center.
Lo-Fi Version | Time is now: 31st May 2024 - 11:15 PM |
