Clutch cable and Speedo cable support, How to mount those cables |
capitolatim |
Apr 17 2017, 11:41 AM
Member Group: Members Posts: 64 Joined: 11-June 15 From: capitola,ca Member No.: 18,841 Region Association: Northern California |
Just finishing up my 2.4/4 install. I want to keep the cable off the headers and better supported. Anyone have some ideas/photos?
Cheers Tim in Capitola Attached thumbnail(s) |
Elliot Cannon |
Apr 17 2017, 12:21 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I wrapped my cables with a heat shield. I also held them away from the headers with adel clamps and spacers. You can easily see the heat shield wrap around the clutch cable in this pic. I also had to protect the oil lines from my external oil cooler.
Attached image(s) |
capitolatim |
Apr 17 2017, 02:28 PM
I wrapped my cables with a heat shield. I also held them away from the headers with adel clamps and spacers. You can easily see the heat shield wrap around the clutch cable in this pic. I also had to protect the oil lines from my external oil cooler. Thanks, where/how did you mount the clamps? |
Elliot Cannon |
Apr 17 2017, 07:00 PM
You can see one of the clamps in the picture. Look just behind the oil filter and just to the right of the oil pan drain. There is a hole on the right side of the oil pan. I used a long bolt and spacer to hold the adel clamp. Unfortunately the other clamps can't be seen in this picture. If you want more it'll have to wait till I can get the car up on the lift again, which should be pretty soon 'cause I need to change the oil soon.
capitolatim |
Apr 17 2017, 10:00 PM
You can see one of the clamps in the picture. Look just behind the oil filter and just to the right of the oil pan drain. There is a hole on the right side of the oil pan. I used a long bolt and spacer to hold the adel clamp. Unfortunately the other clamps can't be seen in this picture. If you want more it'll have to wait till I can get the car up on the lift again, which should be pretty soon 'cause I need to change the oil soon. Elliot, thanks, more photos when you have a chance. Heading your way on Thursday, over to Soda Lake to see the flowers, taking the Corvette. Cheers Tim |
Elliot Cannon |
Apr 18 2017, 12:56 AM
You can see one of the clamps in the picture. Look just behind the oil filter and just to the right of the oil pan drain. There is a hole on the right side of the oil pan. I used a long bolt and spacer to hold the adel clamp. Unfortunately the other clamps can't be seen in this picture. If you want more it'll have to wait till I can get the car up on the lift again, which should be pretty soon 'cause I need to change the oil soon. Elliot, thanks, more photos when you have a chance. Heading your way on Thursday, over to Soda Lake to see the flowers, taking the Corvette. Cheers Tim I flew over that area (very low) Sunday afternoon. (IMG:style_emoticons/default/smile.gif) Millions of flowers. All it takes is a little rain. Drive safe. |
capitolatim |
Apr 19 2017, 09:30 PM
You can see one of the clamps in the picture. Look just behind the oil filter and just to the right of the oil pan drain. There is a hole on the right side of the oil pan. I used a long bolt and spacer to hold the adel clamp. Unfortunately the other clamps can't be seen in this picture. If you want more it'll have to wait till I can get the car up on the lift again, which should be pretty soon 'cause I need to change the oil soon. Elliot, thanks, more photos when you have a chance. Heading your way on Thursday, over to Soda Lake to see the flowers, taking the Corvette. Cheers Tim I flew over that area (very low) Sunday afternoon. (IMG:style_emoticons/default/smile.gif) Millions of flowers. All it takes is a little rain. Drive safe. We didn't make, tried Pinnacles...fewer flowers than our backyard...maybe Monday? |
Lo-Fi Version | Time is now: 1st June 2024 - 08:15 AM |
