Weird flasher |
Weird flasher |
HalfMoon |
May 3 2017, 04:44 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
No, not that kind. And besides, all flashers are probably weird.
This is about the front flashers on my 73. When I turn them on my drivers side is weaker than my passenger side. Examination shows me that the passenger side has both filaments activating but the drivers side only has the lower filament activating. Oddly, using the running lights and both sides have the upper filament activating. Each socket has a hot and a ground and using a test light bears that out, so I'm thinking a switch is wonky? |
Valy |
May 3 2017, 06:42 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Check the ground of the side where both filaments light. That bulb is grounding through the running lights circuit so both filaments light up. It can be the ground wire or the bulb socket or the bulb rusted.
HalfMoon |
May 3 2017, 07:02 PM
HalfMoon |
May 4 2017, 03:11 PM
Dave_Darling |
May 4 2017, 04:57 PM
That is not a proper fix... Something is going on here, and if you don't find the actual problem it may cause more trouble down the road.
--DD |
theer |
May 4 2017, 05:16 PM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
With the ground wire disconnected, nothing should work on that side.
Check that the wires are properly hooked up on both sides front and rear. Also, check the flasher indicator lights in the dash/tach. I had + and - reversed and was getting strange results. Power (+) goes to the connector in the center of the socket, ground (-) on the side connector. Hope that helps. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:54 PM |
