Engine Won't start, My engine does not like warm weather. |
ehick72 |
May 10 2005, 12:02 PM
Member Group: Members Posts: 108 Joined: 28-December 04 From: Austin, Texas Member No.: 3,356 |
I have a 1.7 FI. I haven't had it long so I am still discovering things about my car. One thing that happens every now and then is it won't start and when I finally get it to turn over it idles low and dies during driving. This usually happens on a hot day. It has happened three times now and I have been driving it for about 4 months. However summer is coming and I am concerned about getting stranded.
Otherwise the engine starts up fine, has plenty of power, runs fine. It maybe backfires a little but that's it. Has anyone seen these symptoms before? Eric |
ArtechnikA |
May 10 2005, 12:08 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
in addition to all the normal tuneup stuff that must be up to snuff, i'd find someone who can verify that your fuel pressure is right, and correct it if it's not.
skline |
May 10 2005, 12:10 PM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Check your CHT sensor when you do a tuneup. I had that problem before. D-Jet system.
ehick72 |
May 10 2005, 12:12 PM
It is due for a tuneup. I will see if that helps. Also the FI had about $1500 worth of work done to it before I got it. The may have not put it back together correctly.
Thanks for the help, Eric |
SLITS |
May 10 2005, 12:29 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Like the Shalom owner said.....check the CHT!
Lo-Fi Version | Time is now: 28th May 2024 - 11:18 PM |
