Radio Delete install |
howelljames |
Jun 11 2017, 07:22 AM
Newbie Group: Members Posts: 18 Joined: 27-March 17 From: Sarasota, FL Member No.: 20,967 Region Association: South East States |
rgalla9146 |
Jun 11 2017, 08:25 AM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
It's cake.
Take the radio out and put the cover plate on. I've never seen a plate with the right 'square' pattern for a '75-'76. The tough part is that you'll still have an antenna hole in your fender. |
howelljames |
Jun 11 2017, 09:42 AM
It's cake. Take the radio out and put the cover plate on. I've never seen a plate with the right 'square' pattern for a '75-'76. The tough part is that you'll still have an antenna hole in your fender. Thanks, I hoped it was that easy, but just thought I'd ask. Leaving antenna in place until repaint car, then have plugged. Auto Atlanta sells the proper plate with 75-76 weave. I run stereo thru phone and blu tooth speaker now (radio inop when I bought car) and it's been fine, so want to clean up dash. |
forrestkhaag |
Jun 11 2017, 10:26 AM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
TM_Corey |
Jun 11 2017, 10:33 AM
Member Group: Members Posts: 231 Joined: 28-March 16 From: Indianapolis Member No.: 19,809 Region Association: Upper MidWest |
I just had my antenna taken out during a new paint and it looks so much nicer. I also had my side markers removed.
Matty900 |
Jun 11 2017, 03:46 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
It's cake. Take the radio out and put the cover plate on. I've never seen a plate with the right 'square' pattern for a '75-'76. The tough part is that you'll still have an antenna hole in your fender. Thanks, I hoped it was that easy, but just thought I'd ask. Leaving antenna in place until repaint car, then have plugged. Auto Atlanta sells the proper plate with 75-76 weave. I run stereo thru phone and blu tooth speaker now (radio inop when I bought car) and it's been fine, so want to clean up dash. It is not hard. We sell it with the installation tape. http://shop.914rubber.com/Radio-plates-for...m?categoryId=-1 I will be doing the swap on my car soon from the PO's aftermarket stereo to a factory radio and plan on running an inline bluetooth receiver and running everything through my phone too. What are you using for yours? |
Chris914n6 |
Jun 11 2017, 09:14 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Or you can leave the opening and install a storage bin. DIN size is real common on imports.
If I find which box I hid mine in I'll post a pic. |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:20 AM |
