| kbsmith1973 |
Jun 23 2017, 07:50 AM
Newbie ![]() Group: Members Posts: 4 Joined: 22-June 17 From: Arkansaw, WI Member No.: 21,206 Region Association: Upper MidWest |
I'm trying to replace the air filter element in my 1973 914 1.7L. Fram CA-383 was the prior replacement.
I got one from my local parts store, but it didn't fit properly. Subsequently I ordered one from one of the big Porsche outfits online. It was the same as the one from the local store! The 'recommended' replacement has a larger inside diameter, causing it to miss the sealing ring in the lower part of the housing. It will leak outside air directly into the engine. Internet search has not turned up anything on this issue. Any ideas? |
| BillC |
Jun 23 2017, 08:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
There are a number of threads on this. Turns out the correct air filter is no longer available, despite what the online stores say.
There are, however, filters you can make work. Here's a thread where I made an adapter to use a NAPA Gold 2011 filter. The adapters are pretty simple to make, or I can make one for you ($20 plus shipping). The NAPA web site shows the filter is currently about $7.50 each. If you bought your filter from AutoAtlanta, it's probably the NAPA 2011. At least, that's what they sent me when I ordered a "correct replacement filter" from them 2 years ago. |
| kbsmith1973 |
Jun 23 2017, 12:00 PM
Thanks. I'll try your idea.
Too bad I couldn't dream up the right search keywords... |
| 914_teener |
Jun 23 2017, 01:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
There is a FLAPS replacement that is really close. I had to order it and I thought I posted it a while back. Not at home this weekend but if you can.t find it PM me after this weekend.
| stinkindiesel |
Jun 28 2017, 01:25 PM
Member ![]() ![]() Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I posted this a while back.
Dimensions: Mann C2180 (OEM, NLA) 124mm ID 207mm OD 82mm tall Here's what I'm running now. Wix 42110 125mm ID 163mm OD 76mm tall It's 6mm too short, so I cut a piece of cork gasket material the same size as the filter to fill the extra gap. I found 1/4" to be too much, so I think I've got a couple of pieces in there now that are just under 1/4" total. ![]() ![]() ![]() ![]() Gary |
Lo-Fi Version | Time is now: 16th May 2026 - 08:42 PM |
