Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I had some brake problems at the WCC track day. Got brake fade and was bummed. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Now I have Porterfield race pads for the front and rear. Motul brake fluid. Rebuilt calipers and a "tee" to replace the prop valve. I got the fronts on tonight. Rears are off and ready for rebuilding. I can't wait to take this car deep into the a/x turns at ridiculous speeds. I need to bring up my 914Cup average. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) KT |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Take it to an empty parking lot and do some practice......or go on a twisty downhill...
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
get some vented rotors yet? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
trekkor,
The problem you are having is caused by your excessive use of the center pedal. Use it less, and your problems will fade away.... I use the ATE super blue brake fluid and have had good luck with it. What I have found though, is that you need to get lots of cooling air in to your brakes. If you are running much of a front air dam, you effectively are cooking your brakes due to poor airflow. Without a front airdam, you could use the cool brakes (ducts mounted to your a-arms). With a front airdam, you need to come up with a solution to get air in there. Our track car now has 3" hoses leading from where the fog lights used to be, through the trunk and out to the wheelwells as close to the bulkhead as I could get them. In the wheelwells, I have 2" hoses leading to the coolbrake brake ducts. I no longer get any brake fade. I run 930 brakes up front (which doesn't hurt). Heck, I may need to get heaters to warm them up. |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
Sounds like a good path to better braking! It was probably my fat ass that was causing the extra work on the brakes. Andy said his monster 3.6 was all over the track with me in the passenger seat. Of course he first said, hey Travis - how much do you weigh? heh
Trekkor |
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) yeah, we got one of those... I'll work it out before the next track day. KT |
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
i run 320i fronts with stock rears, and i have never removed my prop valve. at the wcc i had 2 year old ate fluid that i bled ( just enough to get air out ) with castrol lma fluid and i did not have any brake fade. i dont know if that is due to my lack of use of the brakes... no i used them i lot, i was doing 100 mph at the end of the straight.
as for pads i was running pagid front pads, that i found out when the get warm they sweak, but it goes away once the got hot. my rear pads are just what i could get at a local brake place in lancaster. |
TravisNeff |
Scott, didn't you replace your pads at the track at the WCC? or was that the off the shelf stuff you are talking about?
Lo-Fi Version | Time is now: 9th July 2025 - 01:49 PM |
