Pachla |
Newbie ![]() Group: Members Posts: 5 Joined: 3-February 17 From: Georgia Member No.: 20,808 Region Association: None ![]() |
What does the piston retaining plate do on the front brakes? Mine are all bent up.
Bob L. |
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region ![]() |
It prevents the piston from rotating in the caliper bore.
Why? (IMG:style_emoticons/default/confused24.gif) |
Firstcar |
Obsessive amateur mechanic ![]() ![]() Group: Members Posts: 98 Joined: 17-March 11 From: MA -South Shore Member No.: 12,831 Region Association: North East States ![]() |
It prevents the piston from rotating in the caliper bore. Why? (IMG:style_emoticons/default/confused24.gif) Because the face of the piston that contacts the pad has a slight angle to it and is supposed to be installed in a particular orientation in the caliper. I think the designated angle helps the pad bite the rotor properly, prevents pad vibration/squeal and helps the pad wear more evenly. The plate prevents the piston from rotating in its bore ensuring it retains the proper angle. |
Lo-Fi Version | Time is now: 11th July 2025 - 03:35 PM |
