| Keith914 |
Jul 9 2017, 08:34 AM
Member ![]() ![]() Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
I am at final stage of completing my 2.7 911 engine install project. All external oil lines are AN12 stainless steel braided hoses and fittings. I have the scavenger oil feeding directly into an oil filter which is mounted to a bracket with 1/2" fittings for the in and out and for the nipple that the filter screws onto. While starting the engine, as soon as rpm's exceed about 2000 the filter O ring pops out and oil leaks massively. Same result after several attempts. I have a K&N filter that has a large O ring that is not as secure in it's groove as say FRAM filters I am familiar with, and which worked well with this bracket fitting when I had my Type IV in the car. I will be installing a new bracket shortly that has 1/2" in and out hose fittings but a 3/4" nipple for a new typical 911 filter which has a matching 3/4" screw on female fitting. I decided not to install an oil thermostat as I live in a warm climate here in S Cal. Any advice will be welcome.
| mb911 |
Jul 9 2017, 08:42 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,694 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I think 1/2" is to small as stock would be 5/8" internally in the tank. This would increase oil pressure to a certain degree. That said something else seems wrong.
Is something stuck on the oil bypass on the engine? Also i would use the oc54 filter myself. |
| Mark Henry |
Jul 9 2017, 08:44 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Could you explain how you have the oil filter mounted better,
Is it on the tank? Or are you talking about a remote filter adapter like how you would do full Flow on a T1 or 4? What brand and # filter are you using? Fram filters are shit, I used to be a HP-1 lemming till I cut one open. |
| Mark Henry |
Jul 9 2017, 08:49 AM
I think 1/2" is to small as stock would be 5/8" internally in the tank. This would increase oil pressure to a certain degree. (IMG:style_emoticons/default/agree.gif) |
| Keith914 |
Jul 9 2017, 09:31 AM
Could you explain how you have the oil filter mounted better, Is it on the tank? Or are you talking about a remote filter adapter like how you would do full Flow on a T1 or 4? What brand and # filter are you using? Fram filters are shit, I used to be a HP-1 lemming till I cut one open. The oil filter bracket is located on the original battery tray - battery is now in front of car. |
| Steve |
Jul 9 2017, 09:52 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,982 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I know your trying to save money, but if you bought an aftermarket six tank from mb911 your car would most likely be running now. I would be surprised if it's related to the engine.
| Steve |
Jul 9 2017, 09:53 AM
duplicate post
| Mark Henry |
Jul 9 2017, 10:52 AM
| Mark Henry |
Jul 9 2017, 10:54 AM
Not sure what you mean by oil filter bracket.... I'm assuming you mean remote filter adapter.?
| Keith914 |
Jul 9 2017, 11:06 AM
| rhodyguy |
Jul 9 2017, 11:16 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Should that remote require a Mann filter designed for a 4?
| Steve |
Jul 9 2017, 11:20 AM
If your going to go that route, I would check out how Patrick Motorsports does it.
http://www.patrickmotorsports.com/part/rem...ount-set-an-12/ They also list the project cars with pictures on how they use the remote oil filter console. Stock oil tank would be less work.... |
| Mark Henry |
Jul 9 2017, 11:21 AM
Should that remote require a Mann filter designed for a 4? (IMG:style_emoticons/default/agree.gif) You can use a type 4 fillter, Mann, Bosch, NAPA gold. You will pop the O-ring on any cheap filter with even a VW type one oil pump. Way under sized for the large 911 /6 oil pump. You should at least use a remote filter adapter for a tractor/hydraulics. |
| Keith914 |
Jul 9 2017, 11:52 AM
Should that remote require a Mann filter designed for a 4? (IMG:style_emoticons/default/agree.gif) You can use a type 4 fillter, Mann, Bosch, NAPA gold. You will pop the O-ring on any cheap filter with even a VW type one oil pump. Way under sized for the large 911 /6 oil pump. You should at least use a remote filter adapter for a tractor/hydraulics. Patrick's console looks like a well made part, but has the same oil in and out AN 12 fittings I will have on my new bracket, and I am guessing that it has a 3/4" nipple for screwing on the filter. I have a new MAHLE filter which has a 3/4" female "nipple". I am going to cautiously try this filter with the new "3/4" bracket/adapter combination before changing to other solutions you have suggested. Do you have a "adapter for tractor/hydraulics" reference? - I will look on Google. |
| Mark Henry |
Jul 9 2017, 11:59 AM
Same thing you have but in 1" NPT, any hydraulic supply house.
| Keith914 |
Jul 9 2017, 12:09 PM
| thelogo |
Jul 9 2017, 12:28 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Your a brave man sir keith
Putting all this stuff together yourself By the way the old motor is goin great . (IMG:style_emoticons/default/pray.gif) |
| Keith914 |
Jul 9 2017, 01:30 PM
Your a brave man sir keith Putting all this stuff together yourself By the way the old motor is goin great . (IMG:style_emoticons/default/pray.gif) Thanks and I am pleased you are enjoying the 2.36 Ltr. |
| Mark Henry |
Jul 9 2017, 02:14 PM
If it's a mahle I'd look elsewhere than the filter, after the filter it's suppose to just dump into the tank, no real restriction.
Just a thought do you have the flow into the filter backwards? It could be messing with the filter by-pass valve. |
| Keith914 |
Jul 9 2017, 03:15 PM
If it's a mahle I'd look elsewhere than the filter, after the filter it's suppose to just dump into the tank, no real restriction. Just a thought do you have the flow into the filter backwards? It could be messing with the filter by-pass valve. Mark, Thanks for all your input. First, flow direction is correct, - this is a remote filter mounting, and is first in line from the scavenger pump - oil flows on to the front cooler, then back to a custom built tank located in the engine compartment - no thermostat - S. Cal! Next I owe you an apology - the inside non-threaded plumbing in toy old bracket -picture above, is 3/8'" diam, just measured again, and the inlet and outlet ports are 3/8"NPT. My new bracket, just delivered, has 1/2"NPT inlet and outlet ports with corresponding internal plumbing non threaded - much better than smaller old bracket. the filter spin on nipple however is the same 3/4"-16 as the older unit. I need to get AN12 fittings to connect the hoses to these larger 1/2' ports and a good filter to spin on - tomorrow will report back. |
Lo-Fi Version | Time is now: 8th December 2025 - 12:31 AM |
