Engine mount brackets |
JFG |
Jul 30 2017, 04:18 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Can someone tell me the dimensions of the brackets. It would appear I have been sold the wrong ones.
I can cut these and weld them but I don't know how high or low the rubber mount should be. Ideally I need to know the distance between the middle of the top bolt hole down to the top of the small shelf that the rubber bolts onto. |
McMark |
Jul 30 2017, 06:19 AM
Buuuuuuut..... I have no idea what brackets you're talking about....
6 conversion mount? Factory 4 mounts? Outers? Inners? (IMG:style_emoticons/default/confused24.gif) |
JFG |
Jul 30 2017, 06:29 AM
Factory 4 mounts. The ones that bolt to the front of the engine behind the fan shroud
bdstone914 |
Jul 30 2017, 07:28 AM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Factory 4 mounts. The ones that bolt to the front of the engine behind the fan shroud From the bits on info you offered I suspect you were sold VW Bus mounts. Can you post a picture of what you have? If they are bus mounts you can cut, bent and reweld them. I will see if I can post a picture of a correct 914 mount. |
Mark Henry |
Jul 30 2017, 07:45 AM
Bus mounts are on an angle, 914 mounts are flat/level
McMark |
Jul 30 2017, 07:57 AM
I'll assume you're looking at a side-shifter setup. Tailshifter mount bars use a completely different mount (one piece).
(IMG:style_emoticons/default/drunk.gif) Attached thumbnail(s) |
rhodyguy |
Jul 30 2017, 08:00 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The CORRECT later brackets (for a sideshift trans engine support bar) should be readily available via the classifieds.
bdstone914 |
Jul 30 2017, 08:19 AM
Good luck finding used ones. I posted a WTB ad with no replies. The other difference is the square mounting hole location. I could not find a bus mount for comparison. I think you can swap the shelf part side to side and bend and reweld them. Or drill a rounds hole. The square hole matches the square on the top of the mount to keep it from turning. If the engine and bar are out of the car I would jig up the brackets to the engine and use the holes in the bar to get the C-C distance correct for the mount holes and get the shelf parts horizontal.
JFG |
Jul 30 2017, 10:18 AM
Thanks for the info. It looks like they were bus or other air-cooled as they pointed inwards to each when fitted.
I have cut and rewelded them to fit the engine to the bar temporarily just to get the motor in. |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:50 AM |
