Muffler noise question..., can you pack a sport muffler for silence |
DougC |
May 17 2005, 08:59 AM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
I want to convert my stainless Dansk 911 muffler to a 2in 2out Sport Muffler but I think it'll be just too loud. My (possibly dumb) question is this, can you add some kind of muffler packing material to the inside of the muffler (while you're doing the conversion) to quiet it down [just a bit]? I know if sounds crazy but maybe some material like steel wool or something? I really like to two pipes out the back for the /6 and don't mind a good deal of sound, my M3's pretty loud, I just don't want anything louder than that. Also, my 914/6 will be a daily driver and will have CIS which I know is a bit quieter, will that help the overall noise output in regards to the muffler?
Doug C |
Triaddave |
May 17 2005, 09:41 AM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
don't use steel wool!!! try this..take a piece of steel wool and light it on fire...not much left. i would junk the muffler but i am an exhaust guy...
Joe Bob |
May 17 2005, 09:44 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
When converting, leave the stock tip on the side....get caps and use them on times when more silent running is needed. You can run three outlets, cap 1 or two when needed.
DougC |
May 17 2005, 09:58 AM
I thought of the 3 outlets but a couple of things keep me from going that route, first the stock tip on the side is completely "F'd" up, one of the previous owners droped it or dropper the motor that it was attached to and twisted it up real bad, so it has to come off anyway. Second, this will be a daily driver and I'd probably never get to use the dual out set-up if it's extremely loud. I don't know..now that I think about it that might not be a bad set-up really. I'd still have the cool retro look of the two pipes out the back. Got any pics of the 3 pipe set-up?
Doug C |
Joe Bob |
May 17 2005, 10:08 AM
Then put smaller outlets on the muffler and/or weld on larger pipes....No one will see how big the holes in the muffler are unless they get down on their knees and look.
DougC |
May 17 2005, 10:39 AM
You got good ideas, thanks man..
Doug C |
Ferg |
May 17 2005, 10:40 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Doug, I agree that you should do "something" to quiet it down... Since I know exactly how your motor will sound with a two in two out... Here's the only shot I have at work, of the muffler I used and am still using. It is almost unbearable loud between 2500-2900rpms, after that it sounds awesome, but resonates so baldy at low rpms it makes it hard to live with. I plan on taking mine someday to muffler shop to maybe weld in some baffles, but i'm not sure that will help, since my tips (3 inchers) are almost a straight shot from the inlets... Putting the outlets further inboard makes a higher pitched sound, but i'm betting it would still be pretty loud for a DD.
Ferg Poor Pic for reference: Attached image(s) |
DougC |
May 17 2005, 01:19 PM
Thanks for the pic Ferg, but I can't quite make it out, but no biggie..I am going to research the baffles that the Harley (bike) guys use, I think they may just insert into the pipe..think there is a brand named Samson. I'll let you know what I find out.
Doug C |
Ferg |
May 17 2005, 01:50 PM
Yeah, that picture is lousy for a reference... I was trying to illistrate, that my two in and two out is different from what most consider a "sport muffler" my outlets are more in a direct line to the inlets (further to the ends) and since it used to be hooked up to your motor, I have first hand experience of the sound... ie loud.
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Ferg |
DougC |
May 17 2005, 02:51 PM
Ok, check these out..they should take a bit of the sport out of the sport muffler.
Doug C Attached image(s) |
DougC |
May 17 2005, 02:52 PM
oh, I forgot - samsonusa.com
Doug C |
Joe Bob |
May 17 2005, 04:39 PM
Adjusted and cropped....
Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 06:50 PM |
