Keeping it cool!, Advice on keeping my oil temps down |
Localboy808 |
Aug 10 2017, 09:33 PM
Member Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
So over the next few weeks I will be putting my motor back together. I'll be painting the engine compartment first. I will change all the engine bay seals. I've been searching around I can't seem to find a replacement seal that goes on the piece of engine tin against the oil cooler. Is this available anywhere? Any advice would be appreciated! At this time I don't want to do a remote cooler just yet. The motor is a 1.7 case. 1.8 heads and changing the pistons and jugs to make it a 1914? It's got dual 40 Kads at the moment. An an 009.
Scott |
Mblizzard |
Aug 11 2017, 12:58 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
So over the next few weeks I will be putting my motor back together. I'll be painting the engine compartment first. I will change all the engine bay seals. I've been searching around I can't seem to find a replacement seal that goes on the piece of engine tin against the oil cooler. Is this available anywhere? Any advice would be appreciated! At this time I don't want to do a remote cooler just yet. The motor is a 1.7 case. 1.8 heads and changing the pistons and jugs to make it a 1914? It's got dual 40 Kads at the moment. An an 009. Scott 914 Rubber. Call if you cant find on web site. |
914Sixer |
Aug 11 2017, 06:52 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The seal comes on new coolers. Go to the big box stores and get a roll of weatherstrip. Should do the job.
Lo-Fi Version | Time is now: 8th June 2024 - 07:54 PM |
