> Going Megasquirt, Crank sensor installation
Beebo Kanelle
post Sep 14 2017, 11:14 AM
Has anybody installed a crank sensor without dropping the engine?
Any and all guidance and leadership is greatly appreciated.
jd74914
post Sep 14 2017, 11:20 AM
Its alive
I haven't done it (I installed on a bench), but the one from The Dub Shop just required you to pull the fan shroud which can be done in-car IIRC, so you should be able to install without a drop.
VaccaRabite
post Sep 14 2017, 11:23 AM
En Garde!
You can do it. It ins't fun, especially if you don't have a lift.
You have to:
*remove all the front engine tin
*prop up the engine with a jack
*drop the front of the engine down a few inches. It will be pivoting on the trans-mounts, so you don't want to lower it too far.
*pull the dog house. Pull the fan.
*install the trigger and hall sensor.
Install is reverse of disassembly.
Zach
Beebo Kanelle
post Sep 14 2017, 07:16 PM
Thanks to all.
Porschef
post Sep 15 2017, 03:32 AM
How you doin'
Unless there's some overwhelming reason why you shouldn't, (doubtful) drop the engine. It's a bit daunting the first time, but that will allow so many other "while I'm in theres" to occur, it will be well worth it.
It's really not difficult. Just requires being methodical and careful. Good luck.
- Lo-Fi Version Time is now: 1st July 2025 - 11:20 AM
