Any tricks to removing the torsion bar cap? |
echocanyons |
May 21 2005, 11:38 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I am trying to lower the front of my car and the adjustment screw is not enough so I need to re-clock the cap.
I am having trouble getting the cap off are there any tricks to this? Is there any special trick to keeping each side even? I also will need a four corner balance and alignment. Is there any reputable shop in the central cal area that can do this? |
Brad Roberts |
May 21 2005, 12:47 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Hey Kelly,
There is nothing secret about pulling that adjuster out. Pull the actual adjuster screw all the way out/off and stick a small prybar (read that: screw driver) into the slot where you pulled the adjuster screw out and pry towards the back of the car. I reclock them all the time. With the suspension in full droop (car on stands) pay attention to where the adjusters "come from" (their starting location) and reclock them. I normally have to move them down to get the car lower. Sorry I dont have a pick of this. B |
echocanyons |
May 21 2005, 12:59 PM
Thanks Brad I they ended up coming loose they were just stuck with old dried grease.
So to set ride height I should jack the A-arm up so it is even with the ground and grease an reinstall the cap right? |
Lo-Fi Version | Time is now: 8th June 2024 - 04:11 PM |
