echocanyons
May 21 2005, 11:38 AM
I am trying to lower the front of my car and the adjustment screw is not enough so I need to re-clock the cap.
I am having trouble getting the cap off are there any tricks to this?
Is there any special trick to keeping each side even?
I also will need a four corner balance and alignment.
Is there any reputable shop in the central cal area that can do this?
Brad Roberts
May 21 2005, 12:47 PM
Hey Kelly,
There is nothing secret about pulling that adjuster out. Pull the actual adjuster screw all the way out/off and stick a small prybar (read that: screw driver) into the slot where you pulled the adjuster screw out and pry towards the back of the car. I reclock them all the time. With the suspension in full droop (car on stands) pay attention to where the adjusters "come from" (their starting location) and reclock them. I normally have to move them down to get the car lower.
Sorry I dont have a pick of this.
B
echocanyons
May 21 2005, 12:59 PM
Thanks Brad I they ended up coming loose they were just stuck with old dried grease.
So to set ride height I should jack the A-arm up so it is even with the ground and grease an reinstall the cap right?
