Anyone Running 14 inch Wheels?, Thinking about some Dan Gurney's |
Craigers17 |
Sep 28 2017, 02:44 PM
Senior Member Group: Members Posts: 739 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
I was wondering if anyone is running 14" wheels on all 4? I realize this seems like a step backward, and would offer some definite limiting of tire choices in the near future, but are there any other foreseeable problems associated other than speedo issues?
Any reason why stock brakes wouldn't work? -Craig |
r_towle |
Sep 28 2017, 02:54 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
They fit, and I believe it was an option on a /6
arne |
Sep 28 2017, 02:55 PM
Serial Rescuer of old vehicles... Group: Members Posts: 741 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
If you maintain tire diameter close to stock (about 25.0”), no speedo or gearing issues.
But you are correct, not much in 14” sizes in the way of performance tires. |
GeorgeRud |
Sep 28 2017, 03:18 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I still have the 14" Fuchs that came on my 914-6, but agree you can't find many tires that fit. I seem to remember that 195/65-14s would be the closest to being correctsizing. I also thought that the Western Gurney wheels were 15", but I could be wrong. I had them on my 914 2.0 back in the early 70s.
Craigers17 |
Sep 28 2017, 04:22 PM
Thanks for the info! I thought they would be 15's too, but the guy who's selling them seems to be knowledgeable, and says they're 14's. Says they're 6" in rims as well, which is another important factor for me.
We'll see....they are on the Samba, and they're inexpensive and not bad looking. That fits the need for my current project. Thanks again for your help! (IMG:style_emoticons/default/beerchug.gif) |
Racer |
Sep 28 2017, 04:27 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
I run 14" Fuchs on my -6. 195/60-14 tires. Falken Azenis RT615K's that I AX with. Really nice tire.
Tirerack lists some other 14" sizes, some in performance tires too, like Toyo and Hoosier. FWIW, I used to run 6x14 minilites on a -4 car back when 14" tires had greater selection than today. At the time, I could only find 3 minilites in that size. So, I bought two panasport wheels (similar in style to minilites). The panasports would not clear the front caliper but they would clear the rear caliper. So yes, if you run 14" wheels, be mindful of how the backside of the wheel looks and if you can, try it on for size. |
toolguy |
Sep 28 2017, 05:45 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
From the factory, 914-6's only optional Fuch's were 14 x 5.5 Fuchs only. .
With 195/60 x 14 they make for a nice overall gear ratio and sit the car low without dropping the suspension. . The 15 x 5.5 Mahle Gasburners were also a factory option rim for 6's. Any 15 inch Fuchs were after sale installed or selling dealer installed. except the real GT's did have 15 inch Fuchs |
Rand |
Sep 28 2017, 05:46 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Can someone explain to me the benefits of running 14" wheels? Seems wrong to me. Tire choices are only the beginning of the reasons why not. So, why, or not? Are there class categories that restrict you to 14?
garrettlee2 |
Sep 28 2017, 09:08 PM
Member Group: Members Posts: 158 Joined: 8-September 12 From: riverside ca Member No.: 14,901 Region Association: None |
Craigers17 |
Sep 29 2017, 03:40 AM
Thank for the additional info. I went ahead and pulled the trigger on 'em, so I'll give some feedback when I mount them. I found some 205 -55's by Nitto that look pretty sticky as far as performance tires go.
To Rand's question, are there any benefits to running smaller wheels? It looks like many people AX with them, including Miata's etc. Dave/Racer, ....any reason that you are AX-ing with them? Garrettlee2... I agree....I like the lowered look....what size tires and wheel width have you got on that thing? |
IronHillRestorations |
Sep 29 2017, 06:02 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The plus to 14's is a cushier ride. IIRC Porsche offered 14's on "comfort" optioned cars.
The larger issue with 14's is the lack of tire options, the choices are pretty slim. |
Racer |
Sep 29 2017, 09:18 AM
My car came with 6 14" wheels. I run what I got. 15" fuchs are way too m,uch $$ for me. Cookies would be nice, but I haven't pulled the trigger.
Yes, 14"s were part of the "comfort package", but this usually was how it was termed on the 911E that had the pneumatic struts. 14" Fuchs were also used on the 912E. That said, they are lighter... and honestly, how much tire does a 100hp car need? Stock was 165... optional 185. (on a -6). I am running 195 that is IMMENSELY stickier than what was available in 1970 unless you ran Goodyear slicks! Choices are slim. A 205-55-14 could fit, but I was wsorried about rear fender clearance. 195's are a known tire/size that fits and works well. A 195/60-14 is the same overall diameter as a 205-50-15.. so I loose nothing in gearing to the 15" tire. I also get a slightly cushier street ride due to taller sidewalls. And I am convinced that some of the ride characteristics of the car when new are preserved by having the taller sidewall. That said, back when new, my dad would run 195/70 and even a 205/70 on 14's cause, well, that was what was available back then. You don't need a lot of selections.. just 2-3... one or two for "street" use and 1-2 for sportier use imho. |
Rav914 |
Sep 29 2017, 05:36 PM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
I wonder what the Mercedes Fuchs (Bunts, as they're affectionately called) would look like?
These are 14". The come in 15" as well, 5" width to 7", I believe. Five bolt pattern and very plentiful. You almost can't give them away and they're legit Fuchs. Attached image(s) |
Racer |
Sep 29 2017, 05:57 PM
Porsche 5-bolt pattern is 5x130. I believe the MB wheels are 5x112.. so you would need some kind of adaptor at minimum to make the wheels work.
Rav914 |
Sep 29 2017, 07:55 PM
davehg |
Sep 29 2017, 09:39 PM
Member Group: Members Posts: 185 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
I'm planning on using my 14 Fuchs on the 2.7 conversion project. Look great and compliment the sleeper look.
98101 |
Oct 25 2017, 02:17 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
To Rand's question, are there any benefits to running smaller wheels? It looks like many people AX with them, including Miata's etc. I drive a 1991 Miata with the original 14" Daisy wheels. I considered going to 15" wheels when shopping for tires but decided there wasn't any benefit for my use. The 14" wheels and tires are lighter, which reduces unsprung weight (improving handling on uneven surfaces), and rotational inertia (improving acceleration with my tiny engine). |
DM_2000 |
Oct 25 2017, 03:40 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
If you come across 15" MB Bundt cake wheels, they are worth $$ as they were not very common from factory and limited in the aftermarket.
With a bit of magic I run 13" due to the good availability of take off formula car slicks. For street use I run 16". |
Mueller |
Oct 25 2017, 04:47 PM
I wonder what the Mercedes Fuchs (Bunts, as they're affectionately called) would look like? These are 14". The come in 15" as well, 5" width to 7", I believe. Five bolt pattern and very plentiful. You almost can't give them away and they're legit Fuchs. I'm not the only sick person here that thinks those would look cool on a 914. I think the center section needs to be cut down some, then they would look better. |
Mueller |
Oct 25 2017, 04:48 PM
I wonder what the Mercedes Fuchs (Bunts, as they're affectionately called) would look like? These are 14". The come in 15" as well, 5" width to 7", I believe. Five bolt pattern and very plentiful. You almost can't give them away and they're legit Fuchs. I'm not the only sick person here that thinks those would look cool on a 914. I think the center section needs to be cut down some, then they would look better. They are now making replicas in 15x7 which are fairly reasonable cost wise. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:02 AM |
