> Contorl arm gussets for reiforcement of the concul, Made under licence for Middlemotor LLC
Mikey914
post Sep 28 2017, 06:19 PM
The rubber man
We have made these and are handling distribution for Cary. A much needed set of parts at a reasonable price.
Each "kit" consists of 1 set of the 3 pieces to reinforce the consul. We hade these as a single consul kit because, lets face it, one side is more prone to issues than the other.
Thanks Cary
Mikey914
post Sep 28 2017, 06:21 PM
The rubber man
Link -
http://www.shop.914rubber.com/Carys-suspen...area-914SCG.htm
post Sep 28 2017, 07:11 PM
914-6 GT in waiting
Awesome!
bbrock
post Sep 28 2017, 07:15 PM
Awesome! I guess you got my PM. Ordering now. Thanks! (IMG:style_emoticons/default/first.gif)
Mikey914
post Sep 29 2017, 01:12 PM
The rubber man
1st Set out the door.
DM_2000
post Sep 29 2017, 04:29 PM
Are the holes for welding or blind riveting?
If for MIG welding, they are way too small, they need to be 1/2" min and give the installer instructions to strike an arc in the center of the hole ( against the car ) then move outwards in a circular motion to the reinforcement. If this isn't done, all that is accomplished it filling the hole in the reinforcement.
If for TIG welding a 3/8 " hole might be OK since one is able to apply heat exclusive of filler material.
bbrock
post Sep 29 2017, 05:11 PM
QUOTE(Mikey914 @ Sep 29 2017, 01:12 PM) *
And on their way to my house. (IMG:style_emoticons/default/piratenanner.gif)
I believe the holes are for drainage as they are in the originals. These pieces are bead welded around the edges and the holes are needed to weep moisture from the resulting gap. Cary can correct me if I'm wrong, but I assume they go on the same as the factory gussets. This is a terrible picture, but kind of shows how they go. Not pretty, just strong.
- Lo-Fi Version Time is now: 29th November 2026 - 06:36 AM
