CAR Dies, help |
CAR Dies, help |
mxdude914 |
May 22 2005, 07:13 PM
Member Group: Members Posts: 134 Joined: 20-July 03 From: Lodi, CA Member No.: 925 |
When my 73 2.0 gets driven for about 25-35 minutes it shuts off and the fuel pump wont come back on until sitting over night, does anyone know what might be the problem thank you very much in advance.
Joe Bob |
May 22 2005, 07:16 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Hmmm, have you checked grounds? Like the trans strap and the starter wires...pulled the relays on the circuit board? Also...but less likely, when was the last fuel filter changed....if you do cut it open and see how crud is in there....
mxdude914 |
May 22 2005, 07:26 PM
The grounds are good, its got new fuel filters and lines, fuel pump is relocated up front, and yes i have pulled the relays off, and checked them and replaced them, nothing changes.Any other suggestions?
mxdude914 |
May 22 2005, 10:53 PM
would carbs maybe solve the problem i really need help.
MarkG |
May 23 2005, 10:59 AM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
Front or engine area mounted FP? (don't remember when the 914 went to front mounted FP).
If engine compartment mounted, heat related vapor lock. |
Dr. Roger |
May 23 2005, 11:22 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Problem: Ballast resistor powered FP. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Solution: Wire your own from ign switch to FP. No but seriously.. What else would shut OFF a FP? Couldn't you still hear it even with vapor lock? |
cdmcse |
May 23 2005, 12:18 PM
Member Group: Members Posts: 340 Joined: 17-December 04 From: Georgetown, Ky Member No.: 3,305 |
When the car dies, check to see if you have power to the fuel pump, if you do and the pump really has stopped running, I would look at the pump or fuel system. If you don't have power, then I would check the wiring and fuel pump circuits for a problem. At least you could narrow it down. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
mxdude914 |
May 23 2005, 06:36 PM
What is the ballast resistor? could you go more into detail. Also if it is only dying when warmed up would that really be the circuits?. Finally the fuel pump is up front.
Lo-Fi Version | Time is now: 1st June 2024 - 08:13 AM |
