Hot Spark Electronic Ignition, who else has one? |
malcolm2 |
Oct 18 2017, 06:30 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I went with the Hot Spark that replaces the condenser and the points in the disty. After 38000 miles.... maybe 10000 with a new voltage regulator I determined that my module was seriously acting up. That's all in another thread.
This thread is for helping me make sure I don't have problems down the road, so chime in if you can help. The manufacturer recommends, actually requires that you only put 13.7 volts at any RPM into their module. So I tested it after I put my spare module on the car. My 75 L-Jet 1911 cc engine idles perfectly at 950. 1 VOM lead on the coil + the other on ground. Results of the test are as follows: voltage at Idle.... 13.9 -14.2 fail (IMG:style_emoticons/default/barf.gif) voltage at 4000 rpm... 13.6 - 13.9 fail (IMG:style_emoticons/default/barf.gif) Hot Spark says to put a 1.4 ohm Ballast Resistor between the module and coil +... Moved the VOM lead to the exit end of the resistor. Idle....13.9 - 14.2 fail (IMG:style_emoticons/default/barf.gif) 4000...13.5 - 13.68 pass (IMG:style_emoticons/default/KMA.gif) Tried a 5 ohm Ballast Resistor Idle...13.95 - 14.02 fail 4000...13.57 - 13.61 pass 5 ohm BR and the headlights are ON Idle...12.28 - 12.32 pass (IMG:style_emoticons/default/cheer.gif) 4000... 13.29 - 13.31 pass (IMG:style_emoticons/default/cheer.gif) Now I can't drive around with my headlights on all the time. 2ndly I would say that the % of idle time is way less than the 3000 to 4000 rpm driving time. What are your thoughts? Why do I see no change at idle? What else is out there to use instead. This module is only $35 so I figured it was cheap technology. It was simple and maintenance free. Bolt it on and plug it in. |
DRPHIL914 |
Oct 19 2017, 07:59 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
ive had the same hot spark module for past 5 years, no issue.
ive not had a problem but I didn't put a resistor in there either - but I do have their coil too - this will not matter once I get the I 123 distributor on the group buy! |
malcolm2 |
Oct 19 2017, 10:53 AM
ive had the same hot spark module for past 5 years, no issue. ive not had a problem but I didn't put a resistor in there either - but I do have their coil too - this will not matter once I get the I 123 distributor on the group buy! Good to know someone has used their product with success. I assume you never did the tests? How many miles you figure on yours? I recently bought their coil too. So the recent tests using the resistors are with their coil. the 2ndry R was 7000 ohms, as they suggested. primary was 3.3 ohms, also as they suggested. My previous coil was 9400 & 3.6, respectively. I would still consider my original as GOOD, passing all their tests. I just don't understand why the resistor has no effect on the voltage while at idle. |
porschetub |
Oct 19 2017, 06:59 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have an original SVDA type but its the Bosch unit,have hotspark on it but not yet installed ,I researched a fair amount before buying appears they are fine,however they haven't sold in the numbers that Pertronix have so documented failure would be less I suspect.
My unit was UK sourced and came with a Lucas gold 3.0 ohms coil but I believe there was mention of the Bosch blue coil working also. Never saw any mention in the instructions of a resistor,maybe that's for use with a stock coil ?,truly I really don't know. |
Retroracer |
Oct 19 2017, 08:22 PM
Senior Member Group: Members Posts: 616 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
The operating spec from Hot Spark is curious to me - as the voltage regulator spec for most of our cars is rated at a nominal 14V (i.e. over the suggested 13.7V maximum!).
If I was trying this set up, I'd be wiring in a 1N4001 diode in series with the Hot Spark feed (instead of a ballast resistor); this will drop around 0.5V - 1V from the regulated voltage which should keep the Hot Spark in spec...? You may need to exercise some soldering skills, and the diode should be widely available (eg RadioShack..) |
scott_in_nh |
Jan 22 2018, 12:22 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
Old thread - just seeing this now as I am doing research on a voltage regulator replacement.
Has your situation been resolved? I've had the Hot-Spark unit in my 914 since 2011 or so and over 30k of driving and have never had a problem with it even though my charging system has been sketchy at best the entire time. |
timothy_nd28 |
Jan 22 2018, 12:39 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
In helping others with their Ljet issues, I have found a few hot spark modules acting goofy. Currently, the hotspark module in my 914 is acting very goofy and is misfiring at idle (had it for over 5 years). I was a huge proponent for this 30 dollar module, but now I'm steering folks away and advising the 123 dizzy instead.
scott_in_nh |
Jan 22 2018, 01:21 PM
In helping others with their Ljet issues, I have found a few hot spark modules acting goofy. Currently, the hotspark module in my 914 is acting very goofy and is misfiring at idle (had it for over 5 years). I was a huge proponent for this 30 dollar module, but now I'm steering folks away and advising the 123 dizzy instead. When it gets to the top of the list, I will get the 123 dizzy, it looks and sounds like a real nice upgrade, but 5 years out of a $30 to $50 part is a bargain. I haven't even had the cap off the distributor or adjusted the timing after all the miles and time! |
malcolm2 |
Jan 23 2018, 12:35 PM
I have not tested or changed anything since October. Have made a few trips and drive to work on most dry days. I still would like to try RETRO RACER's idea, but just have not gotten to it.
I keep a spare Hot Spark in the trunk for the next failure and then I guess it will be back to the points and condenser or to the new disty. (IMG:style_emoticons/default/confused24.gif) Depends on how I feel at the time. Did you see the post I did with Tim's help using the timing light? It really shows the "cut-out" across all 4 cylinders. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:30 AM |
