I went with the Hot Spark that replaces the condenser and the points in the disty. After 38000 miles.... maybe 10000 with a new voltage regulator I determined that my module was seriously acting up. That's all in another thread.
This thread is for helping me make sure I don't have problems down the road, so chime in if you can help.
The manufacturer recommends, actually requires that you only put 13.7 volts at any RPM into their module. So I tested it after I put my spare module on the car.
My 75 L-Jet 1911 cc engine idles perfectly at 950. 1 VOM lead on the coil + the other on ground.
Results of the test are as follows:
voltage at Idle.... 13.9 -14.2 fail
voltage at 4000 rpm... 13.6 - 13.9 fail
Hot Spark says to put a 1.4 ohm Ballast Resistor between the module and coil +... Moved the VOM lead to the exit end of the resistor.
Idle....13.9 - 14.2 fail
4000...13.5 - 13.68 pass
Tried a 5 ohm Ballast Resistor
Idle...13.95 - 14.02 fail
4000...13.57 - 13.61 pass
5 ohm BR and the headlights are ON
Idle...12.28 - 12.32 pass
4000... 13.29 - 13.31 pass
Now I can't drive around with my headlights on all the time. 2ndly I would say that the % of idle time is way less than the 3000 to 4000 rpm driving time.
What are your thoughts? Why do I see no change at idle? What else is out there to use instead. This module is only $35 so I figured it was cheap technology. It was simple and maintenance free. Bolt it on and plug it in.
