Carbs to D-Jet - Need advice, Reinstalling D-Jet |
kahluver |
Oct 19 2017, 01:13 PM
Newbie Group: Members Posts: 49 Joined: 3-October 14 From: Huntington Beach, ca Member No.: 17,973 Region Association: Southern California |
My '74 2.0 is running dual Dellortos and I've been wanting to restore my engine back to D-Jet. I was able to score a full and working D-Jet system including wiring, ECU and all hoses, FI, etc...
How difficult is it to go back to D-Jet from carbs? Aside from the D-Jet system, I also expect to have to go back to a high-pressure fuel pump and should probably replace the fuel lines as well. Has anyone put D-Jet back into your car? If so, was it a real PITA? Any tips or tricks to this? I'm pretty good with mechanicals but I'm new to FI. I've restored several other old air-cooled cars. Should I try installing this myself or is this better left to someone more familiar with these D-Jet systems? |
BeatNavy |
Oct 19 2017, 02:01 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Absolutely can be done and has been done. The only real gotcha is to know whether or not your engine has a non-stock cam that is friendlier to carbs. If so, then going back to D-Jet is not a good option. Do you know the engine build history?
Yes, you'll need a high-pressure fuel pump. The two-port Bosch works well (I just replaced my 3-port with this last weekend - much better starting experience). Physically installing everything is not hard. Assuming that all the bits and pieces are compatible from the same system (e.g., '72 2.0) and are in good working order, it's something most people can do if they are so inclined and willing to learn. Lots of resources available (e.g., https://members.rennlist.com/pbanders/djetparts.htm) as well as here on the world. So my tip is: Read up and learn more about D-Jet. Make sure you have all the right parts. Test them before you try to use them (that link has good diagnostic info). Having said all that, I'm a fan of D-Jet. It was a steep learning curve, but I enjoyed the process. |
thelogo |
Oct 19 2017, 03:07 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I was able to score a full and working D-Jet system including wiring, ECU and all hoses, :bull stromberg:
Working , according to whom , the guy who sold it too you How much did it set you back |
GregAmy |
Oct 19 2017, 03:30 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I've come to like the D-Jet (though not the relay plate). My only concern with a FI->carb conversion is that some wiring may have been modified or removed. You got everything, right? A new engine harness from Bowlsby (on my wish list) is just over $450.
saigon71 |
Oct 19 2017, 03:41 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Like Rob said, you really need to find out what cam is in that engine before going any further.
kahluver |
Oct 19 2017, 04:24 PM
Thanks so much for the advice. As you can see I'm a newbie on 914 FI.
Unfortunately I have no idea on the cam in my current motor as the prior owner didn't have it's build history. Is there any way to tell by how the car runs? I'm running carbs and the car seems to run well. I've driven the car across the country and the only issue was I needed to raise the idle at altitude (5000 feet) or it'd die. This is my only 914 so I wouldn't know how this compares to a carb'd car with the "carb cam". |
Lo-Fi Version | Time is now: 1st June 2024 - 01:09 PM |
