Need to beg borrow or rent!, A-frame need to hang front lid to paint |
mgphoto |
Oct 24 2017, 02:07 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I was hoping I could find someone in the North Los Angeles area ie San Fernando Valley, Burbank and Glendale.
I am about to paint my front lid. I painted my rear lid on a fender stand and did not do a good job on the underside. I know I can get both sides painted hanging the lid on an A-frame paint stand. I would only need it 2 - 3 days at most, I can pick it up in my pick up and return it to you. Thanks in advance. Mike |
mgphoto |
Oct 24 2017, 02:10 PM
mgphoto |
Oct 24 2017, 02:55 PM
worn |
Oct 24 2017, 02:57 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I was hoping I could find someone in the North Los Angeles area ie San Fernando Valley, Burbank and Glendale. I am about to paint my front lid. I painted my rear lid on a fender stand and did not do a good job on the underside. I know I can get both sides painted hanging the lid on an A-frame paint stand. I would only need it 2 - 3 days at most, I can pick it up in my pick up and return it to you. Thanks in advance. Mike I thought it was easier to paint flat. My problem with these is always dust and debris from under the iunderside spider frame. But if you paint that first and let it cure you can mask it and then go for the big flat side. |
ValcoOscar |
Oct 24 2017, 03:02 PM
Garage Life Group: Members Posts: 2,389 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I have one you can borrow for a few days if you are willing to pick up in Huntington Park 90255.
PM me if interested Oscar |
Elliot Cannon |
Oct 24 2017, 03:23 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Make one out of PVC pipe. Cheap, easy and when done you can keep it for other uses or just toss it. (IMG:style_emoticons/default/biggrin.gif)
JOEPROPER |
Oct 24 2017, 03:30 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Make one out of PVC pipe. Cheap, easy and when done you can keep it for other uses or just toss it. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) that's what I was thinking. you could even take it apart when done and store it in the corner. |
mgphoto |
Oct 24 2017, 03:46 PM
I was hoping I could find someone in the North Los Angeles area ie San Fernando Valley, Burbank and Glendale. I am about to paint my front lid. I painted my rear lid on a fender stand and did not do a good job on the underside. I know I can get both sides painted hanging the lid on an A-frame paint stand. I would only need it 2 - 3 days at most, I can pick it up in my pick up and return it to you. Thanks in advance. Mike I thought it was easier to paint flat. My problem with these is always dust and debris from under the iunderside spider frame. But if you paint that first and let it cure you can mask it and then go for the big flat side. Hey worn, I had the lid garnet blasted, there were some leftover garnet bits but the reason I bought this lid was the fact that the inner bracing was still connected to the outer skin, and there wasn't much inside the bracing. I spent a lot of time with my original rear lid, adding adheasive between the brace and the skin to add strength and stability to the lid, which was sat on a number of times, this was gonna be a piece of cake. Laying it flat could be easier but not faster, I said I would get around to the inside of the rear lid, but 6 months later, not done. It took me 6 weeks to finish the rear lid, I am on week 3 and holding for the wind. |
mgphoto |
Oct 24 2017, 03:50 PM
mgphoto |
Oct 24 2017, 03:57 PM
Jeff Hail |
Oct 24 2017, 07:19 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
whitetwinturbo |
Oct 25 2017, 09:03 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Home Depot pvc time (IMG:style_emoticons/default/beer.gif)
Mueller |
Oct 25 2017, 09:05 PM
Just make sure to support the legs so they don't spread open! |
mgphoto |
Oct 30 2017, 11:20 AM
Have to thank ValcoOscar, got it painted yesterday, not much sun today.
mgphoto |
Oct 30 2017, 11:23 AM
rjames |
Oct 30 2017, 12:37 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I see more sanding in your future.
I've always wanted to pain my car myself, but afraid of how much work it would really be. I'm impressed with anyone willing to take it on. |
ValcoOscar |
Oct 30 2017, 03:37 PM
mgphoto |
Oct 31 2017, 03:27 PM
Have to thank ValcoOscar, got it painted yesterday, not much sun today. No worries Mike..glad I could help out. Take your time returning frame...let your hood cure as much as possible. Next week anytime is fine. Oscar Thanks again Oscar. |
Rand |
Oct 31 2017, 04:09 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I see more sanding in your future. Oof, no kidding. Not sure this frame helped anyone except the runs. Laying flat and painting each side on different days may have been a better choice. Could have just hooked it on the gutter with those s hooks if you paint outside. (It may sound like I'm giving you a hard time... take that with a grain of salt.) I painted my first car outside. I thought it was smart to paint early in the morning because it was calm. I didn't think about bugs. Had a couple land on it, and then struggle to their death, leaving a wake in the paint and a nice nugget at the end. Ugh. Sometimes we do things thinking it's a good idea and it backfires. |
mgphoto |
Oct 31 2017, 04:45 PM
Lo-Fi Version | Time is now: 9th June 2024 - 11:45 PM |
