Where can I find these?, Firewall seatbelt retaining "U" bolt |
ottox914 |
Nov 8 2017, 06:11 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Mikey914 |
Nov 8 2017, 06:30 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You really need them to attach to a bar, or at the very least will need significant reinforcement to the sheet metal.
tygaboy |
Nov 8 2017, 06:36 PM
914 Guru Group: Members Posts: 5,303 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I think you can get the kit from Mittelmotor in Germany.
They do a bunch of 914/6 GT replica parts. |
914forme |
Nov 8 2017, 07:00 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Yes you need to reinforce the farewell with a backer. lots of places sell FIA backers that can be put in place. Also be careful on the angles that they need to be set at so they work properly.
Retroracer |
Nov 8 2017, 08:48 PM
Senior Member Group: Members Posts: 616 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
So McMaster-Carr stock some Stainless steel U bolts that work for 2" belts, which are a) reasonably priced and b) look like the Repa style ones (well, from 100 yards away). I used these on my GT-like build (see photo) and am pretty happy with the result. I would second the comments about backing plate / bulkhead reinforcement made above; also welded in is always better.
<Fairly Obvious Disclaimer Section: I should point out that these parts are obviously not intended or recommended for this purpose - and this is very much a safety issue, which you may not (understandably) be comfortable with. Your decision, your risk.> Attached thumbnail(s) |
sithot |
Nov 8 2017, 09:09 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
infraredcalvin |
Nov 8 2017, 11:16 PM
Distracted Member Group: Members Posts: 1,524 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Member here that is making these, nice looking product... these are on my list...
http://www.914world.com/bbs2/index.php?sho...=315074&hl= |
sithot |
Nov 9 2017, 05:59 AM
Member here that is making these, nice looking product... these are on my list... http://www.914world.com/bbs2/index.php?sho...=315074&hl= Marek is a very talented fabricator. |
Lo-Fi Version | Time is now: 4th June 2024 - 06:52 PM |
