headlamp "whiskers", what are these called and where can I get new ones? |
914 RZ-1 |
Nov 26 2017, 06:25 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm looking for the plastic "whiskers" that seal or clean the actuating arm on the headlamps. In the attached picture, I have removed the headlamp.
I looked in the PET and could not find them in the exploded view for the headlamp assembly (page 298). What are these called and where can I buy them? Thanks! |
mepstein |
Nov 26 2017, 06:43 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mark said 914rubber will make them soon.
Mikey914 |
Nov 28 2017, 12:07 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just finishing the forming, I can get you a set in a few days. Along with the pivit bushings for the headlight assembly and the rotating metal arm.
Mark |
douglastic |
Nov 28 2017, 02:22 PM
not a real person Group: Members Posts: 58 Joined: 7-November 16 From: Beaumont, CA Member No.: 20,566 Region Association: Southwest Region |
Just finishing the forming, I can get you a set in a few days. Along with the pivit bushings for the headlight assembly and the rotating metal arm. Mark well holy f - that's obscure! is there anything mike can't do?? when i am finally able to buy and work on a 914, i have a feeling it could end up more 914rubber bits than porsche! (IMG:style_emoticons/default/pray.gif) |
mepstein |
Nov 28 2017, 02:38 PM
Just finishing the forming, I can get you a set in a few days. Along with the pivit bushings for the headlight assembly and the rotating metal arm. Mark well holy f - that's obscure! is there anything mike can't do?? when i am finally able to buy and work on a 914, i have a feeling it could end up more 914rubber bits than porsche! (IMG:style_emoticons/default/pray.gif) That’s a good thing. Mikey is less expensive than Porsche. |
MikeM |
Nov 28 2017, 03:16 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Sorry for the hijack... Mark, any word on the upper front strut bushings?
Thanks |
Mikey914 |
Nov 28 2017, 04:44 PM
Upper fronts are done I'm very happy with this. The poly graphite is very solid and I used a press to mechanically wedge these in on the metal. Could be done on a bench vise easily too. We are trying to finish up a custom tool for the A arm bushing install and we have made the new rubber version of them that are correct (NOT A URO PART) and the tool will make the job easier.
So we have those 2 parts and have just finished the trailing arm poly bronze bushings as well as the arm support arm tubes in solid stainless. I'll post up some more car porn later. Mark |
mepstein |
Nov 28 2017, 04:52 PM
Upper fronts are done I'm very happy with this. The poly graphite is very solid and I used a press to mechanically wedge these in on the metal. Could be done on a bench vise easily too. We are trying to finish up a custom tool for the A arm bushing install and we have made the new rubber version of them that are correct (NOT A URO PART) and the tool will make the job easier. So we have those 2 parts and have just finished the trailing arm poly bronze bushings as well as the arm support arm tubes in solid stainless. I'll post up some more car porn later. Mark I'm for 2-3 cars worth. |
914 RZ-1 |
Nov 28 2017, 09:11 PM
djway |
Nov 30 2017, 02:59 AM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
What years had the fuzzies? I have had many 914s and I don't recall ever seeing them.
I just replaced all the bushings on the project car with All Thread and some plumbing parts. Did not take long. Having the part that presses on the bushing would save some time in the plumbing isle at the hardware store. |
mepstein |
Nov 30 2017, 07:49 AM
What years had the fuzzies? I have had many 914s and I don't recall ever seeing them. I just replaced all the bushings on the project car with All Thread and some plumbing parts. Did not take long. Having the part that presses on the bushing would save some time in the plumbing isle at the hardware store. 70 & 71 had fuzzy’s. I’m not sure about 72. |
BeatNavy |
Nov 30 2017, 08:01 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
What years had the fuzzies? I have had many 914s and I don't recall ever seeing them. I just replaced all the bushings on the project car with All Thread and some plumbing parts. Did not take long. Having the part that presses on the bushing would save some time in the plumbing isle at the hardware store. 70 & 71 had fuzzy’s. I’m not sure about 72. I have a 72. I'm pretty sure it does not have fuzzy's. |
Mikey914 |
Nov 30 2017, 09:22 AM
Matt's 72 had them. That's where we got the idea. So the cut off is somewhere in there.
mgphoto |
Nov 30 2017, 09:30 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
My '72 has them and an additional rubber flap that goes in front of the horse hair.
My chassis is I think April build. I know that '73 have the rubber cup that encloses the headlight motor pivot, kinda looks like an old time horn. |
BeatNavy |
Nov 30 2017, 01:38 PM
Mikey914 |
Nov 30 2017, 01:48 PM
Noticed that when we bent these up we made slightly too narrow. Going to have to cut more up and take another wack at it. The die we made to bend them took metal from the width and added to the brush height..... doooooo (IMG:style_emoticons/default/headbang.gif)
Attached thumbnail(s) |
Eric_Shea |
Nov 30 2017, 01:54 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Rumor has it Mark and Matt are working on these...
Mikey914 |
Nov 30 2017, 02:47 PM
I'll leave this for brand U
Attached image(s) |
bobheinonen |
Nov 30 2017, 07:26 PM
Newbie Group: Members Posts: 10 Joined: 16-September 08 From: San Diego, CA Member No.: 9,556 Region Association: Southern California |
All 914s have these headlight brush strips --- 2 per car. Part number is 914.750.079.10. Best bet is 914rubber or used. Bob Heinonen
windforfun |
Nov 30 2017, 08:11 PM
Senior Member Group: Members Posts: 1,838 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
My "73 doesn't have them. It has really fat rectangular grommets. It's 99 % stock with only 48 K miles. Whatever.
Lo-Fi Version | Time is now: 9th June 2024 - 09:44 PM |
