Fatboy007 |
Member ![]() ![]() Group: Members Posts: 62 Joined: 23-May 17 From: San Diego, ca. Member No.: 21,124 Region Association: Southern California ![]() |
So yeah...75 fi...Smell gas when running. Does the fuel line run along the center section with the linkage? (IMG:style_emoticons/default/blink.gif)
designerguy90 |
Member ![]() ![]() Group: Members Posts: 52 Joined: 21-July 14 From: Chicagoland Member No.: 17,666 Region Association: None ![]() |
Yes. The feed and return lines run in the center tunnel. Assuming they are still the original plastic lines, its probably time for them to be replaced. The stainless steel line set from Tangerine Racing is fantastic, and is a fairly easy install, though my engine being out at the time probably helped matters a bit.
mzalanka |
Member ![]() ![]() Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None ![]() |
Def check send & return lines in the tunnel. Don’t drive until you rule out a leak in the engine compartment. Check fuel line connections in the engine bay to the return lines and FI rails. Also check injector seals including cold start valve at plenum. If you can smell it in the cabin though it’s probably a front trunk issue. Check rubber fuel line connections under tank in the front trunk (accessible from underneath pass side - need to jack up & remove gravel shield). Also possible/probable the emission canister/hose is removed and the tank is venting to the front trunk. Fuel tank cap might not be completely on; gasket could be missing/cracked; gasket from plastic expansion tank to tank also could be missing or cracked. |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Look underneath the car see if you see something dripping more often than not it's in the very front section where the fuel filter is in the pump.
Coondog |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Change all fuel lines. Several vendors sale the SS lines. Good time to change FI lines and don’t forget the green gas cap gasket |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Don't overlook the hoses from the fuel tank to the fuel pump Under the tank.
Steve Snyder |
Member ![]() ![]() Group: Members Posts: 241 Joined: 10-June 08 From: Graham, NC Member No.: 9,158 Region Association: South East States ![]() |
Assuming there is not a puddle of gasoline under your car, the first things I would check/replace are the short line from the gas tank to the evaporation tank, the vent line from the evaporation tank, and the tank filler gasket. Failure of any of those items leads to gas fumes in the cabin when running, and they are much simpler to replace than the fuel lines in the tunnel (although replacing 40+ year-old plastic lines that carry gasoline through the cabin of your car is a good idea regardless).
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Does the front trunk smell of fuel? If so, and the hoses under the tank are OK, you may have pin-holes in the tank. The tank partly sits on three felt pads glued to the inside of the compartment, and they have been known to trap water and lead to pinhole rust-through.
--DD |
forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
Or how about the expansion tank and/or the fume canister may spent. Is it a smell on hard cornering to the left? Several things can contribute but the above advice is all good / replace plastic lines with SS (cheap at Pep Boys) and all things-gas in the engine bay. Drive Man, Drive!
(IMG:style_emoticons/default/beerchug.gif) |
Fatboy007 |
Thanks folks... I'm gonna check it out tomorrow... What an awesome community (IMG:style_emoticons/default/pray.gif)
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
ooops sorry Stacey! old thread or last December thread of yours. All fuel lines replaced and has the SS tunnel lines and at the engine bay. Did you find where the smell is coming from? I hope just the charcoal canister since I didn’t refill it with charcoal.
ValcoOscar |
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,393 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California ![]() ![]() ![]() |
Stacey-
You, or you and Noel are welcome to use my 2 post lift in OC should you need to. Just saying Just PM me Oscar |
ndfrigi |
larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
X2 - look hard at the vapor lines & connections at the tank/canister
very common problem - many old threads on this - we are all asssuming that all of those are still intact as oem? (not common) Or how about the expansion tank and/or the fume canister may spent. |
Lo-Fi Version | Time is now: 16th June 2024 - 11:00 AM |
