CSP linkage, return spring |
80cap |
Jan 8 2018, 08:35 AM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Did CSP ever make a return spring for there linkage system?
Brian |
RoadGlue |
Jan 8 2018, 01:19 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Last weekend I rearranged my linkage so that the bars were parallel to one another and I think in doing so you can now use the CSP return spring If you see the way the spring is wound and then compare it to where I have my current return spring, then I think it's wound the right direction to work. I'm at work and need to make sure I find the right spring for my kit. Once I do that I'll report back after I've received it. |
80cap |
Jan 8 2018, 01:34 PM
Thanks for the reply. Does CSP make a spring?
mobymutt |
Jan 8 2018, 03:37 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
RoadGlue |
Jan 8 2018, 03:41 PM
"CSP bellcrank linkage for Type-1 standard fan shroud"
That doesn't seem correct ;-) |
mobymutt |
Jan 8 2018, 03:46 PM
80cap |
Jan 8 2018, 03:55 PM
I am not sure but I think it winds the wrong way.
mobymutt |
Jan 8 2018, 04:03 PM
The other one they offer is this:
https://www.cip1.ca/ProductDetails.asp?Prod...29%2D881%2D100A But you can see it goes with the 'billet' bracket in the 2nd little picture, which is definitely not what I got. Edit: sorry for the .ca link, I think you change just change it to .com. |
SA-914 |
Jan 9 2018, 09:58 AM
Member Group: Members Posts: 128 Joined: 30-June 14 From: San Antonio,tx Member No.: 17,566 Region Association: Southwest Region |
That one from CIP is correct. I had the same type of problem, where they sent me the spring that said it was for the stamped steel. Cip sent me the billet one, and it works better, but I still had to add a secondary spring.
The other one they offer is this: https://www.cip1.ca/ProductDetails.asp?Prod...29%2D881%2D100A But you can see it goes with the 'billet' bracket in the 2nd little picture, which is definitely not what I got. Edit: sorry for the .ca link, I think you change just change it to .com. |
gothspeed |
Jan 10 2018, 03:24 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
CSP linkage! (IMG:style_emoticons/default/w00t.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 02:16 AM |
