Installing new M/C, How to bend the lines fron resovoir to M/C |
deemsriddle |
Feb 2 2018, 08:07 AM
Newbie Group: Members Posts: 15 Joined: 1-January 17 From: Ringgold GA Member No.: 20,717 Region Association: South East States |
I am installing new lines from the master cylinder to the reservoir. The factory lines appear to be pre bent. I tried heat from hair dryer to bend the lines but the line buckled. Any tips?
ChrisFoley |
Feb 2 2018, 08:36 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I am installing new lines from the master cylinder to the reservoir. The factory lines appear to be pre bent. I tried heat from hair dryer to bend the lines but the line buckled. Any tips? I don't think they were pre-bent. The tubing should be somewhat flexible. They probably took a set over time, but the clips that secure them were necessary to hold the shape when new. |
Mikey914 |
Feb 2 2018, 12:35 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Metal lines are pre bent not plastic. Easy to replace.
marksteinhilber |
Feb 2 2018, 12:48 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
I am installing new lines from the master cylinder to the reservoir. The factory lines appear to be pre bent. I tried heat from hair dryer to bend the lines but the line buckled. Any tips? Bench bleed MC before installing if you change MC. Install reservoir lines into MC before installing MC. reservoir lines can then be slid into place and grommets installed. reservoir lines are very difficult to install into the MC when it is in the car. it is hard to grip them and know that they are properly seated into the rubber grommet in the MC. I fought this job in the car. it was simple with MC outside the car. |
SKL1 |
Feb 2 2018, 02:32 PM
Senior Member Group: Members Posts: 1,603 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Or get a new MC with the easy install option from 914rubber...
Lo-Fi Version | Time is now: 7th June 2024 - 05:27 AM |
