Hydraulic Clutch Reservoir, What did you use, and how did you mount it |
Mowog4 |
Feb 4 2018, 10:55 AM
Member Group: Members Posts: 291 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I am hoping someone can point me in the direction of where they mounted a clutch master cylinder reservoir. I know I have seen it before but have been U.N. able to find it. Please help,
Thanks Ed |
A&P Mech |
Feb 4 2018, 01:06 PM
Member Group: Members Posts: 401 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
This is where I mounted mine. Check my build thread post 133.
effutuo101 |
Feb 4 2018, 01:12 PM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
I don’t have any of the heater stuff. I used a Tilton 3 reservoir to handle front, rear and clutch.
Attached thumbnail(s) |
Mowog4 |
Feb 4 2018, 03:31 PM
76-914 |
Feb 5 2018, 09:25 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
When you finish that thing, pm me and I'll send you a VW/Subaru decal for your car. (IMG:style_emoticons/default/beerchug.gif)
Mowog4 |
Feb 6 2018, 09:22 PM
When you finish that thing, pm me and I'll send you a VW/Subaru decal for your car. (IMG:style_emoticons/default/beerchug.gif) I am hoping for a first drive this weekend |
GeorgeRud |
Feb 6 2018, 09:58 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Do you have a picture of your clutch master and slave cylinders?
76-914 |
Feb 7 2018, 01:08 PM
When you finish that thing, pm me and I'll send you a VW/Subaru decal for your car. (IMG:style_emoticons/default/beerchug.gif) I am hoping for a first drive this weekend Super! Remember, baby steps at first. Also, you may or may not have some teething issues so I recommend that you drive exactly the same route each time and carry a watch. It helps to do all of these test runs at the same OAT if possible. Knowing time, distance and temp will make it easy to chart your runs and greatly assist in diagnosing some problems. Kindly provide us a some pics or a video. Make one of those pic's of you with a huge (IMG:style_emoticons/default/stromberg.gif) eating grin on your face. (IMG:style_emoticons/default/beerchug.gif) |
914forme |
Feb 7 2018, 03:01 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
I don’t have any of the heater stuff. I used a Tilton 3 reservoir to handle front, rear and clutch. That Tilton three chamber is what I used and Scott is using on PORSTI and Grey Matter Builds, solves the issue with the other stuff that leaks at the bottom. You can get it with press on fittings or AN fittings. It will fit with the heater stuff in place, you just have to build the mount. Somewhere in the build thread I have one made up. A little (IMG:style_emoticons/default/smash.gif) in a vice I need a Magna Brake Make my stuff look so much better |
Lo-Fi Version | Time is now: 10th June 2024 - 04:57 AM |
